Question about Acer (ALW-1123-A) Ethernet Switch (ALW1123A)
Problem during istallation new hardware for examlpe modem
Problem during installation new hardware
Re: problem during istallation new hardware for examlpe...
Please state the exact problem so you can get better assistance.
Posted on Feb 18, 2008
0 characters
3 Points
How do i fix after modem reset
Basically, you unplug all of the Netgear Xe104 units, wait a minute, then plug the one nearest to the Router back into a wall socket first. Wait a few seconds then plug in a second Xe104 and give it a minute to "talk" to the first unit. Then plug other Xe104's in one at a time. Below you'll find the official troubleshooting steps which you should read carefully if the basic steps above do not resolve the problem.
Also, i should tell you that Powerline adapters such as yours have improved greatly in the last few years, and you can buy a pair of new ones that are very, very much faster than yours for a very modest cost. For example, TP-LINK TL-PA4010KIT
or NETGEAR Powerline 500 1-Port Starter Kit (XAVB5201) or
ZyXEL PLA4225 4-Port 500 Mbps Powerline Gigabit
XE104 User Guide 4-2 Troubleshooting v1.0, September 2005
Power Light Not On Make sure that, if power to the AC power outlet is controlled by a wall switch, the wall switch is in the on position. Verify that the wall socket is live by disconnecting the XE104 85 Mbps Wall-Plugged Ethernet Switch and plugging in some other electrical product, such as a lamp or a hairdryer. If the error persists and you have confirmed the power outlet you are using is live, you have a hardware problem and should contact technical support.
HomePlug Light Not On If the power light is on but the HomePlug light is not, check the following: • Make sure that power is being provided to more than one PowerLine device. Another PowerLine device must be installed for successful communication across the PowerLine. • Verify that the network password is the same on all devices in the PowerLine network.
Ethernet Light is Off • Make sure that the Ethernet cable is plugged in properly at both ends. • Be sure you are using the correct cable on the router that the first XE104 is connected to. When connecting the router's Internet port to a cable or DSL modem, use the cable that was supplied with the cable or DSL modem. This cable could be a standard straight-through Ethernet cable or an Ethernet crossover cable. • On attached Ethernet device or network adapter card, check that the Link light is
Feb 25, 2015 | NetGear Xe104 Wall Plugged Ethernet Switch...
I am trying to network 2 comoputers through the netgear 5-port fast ethernet switch FS605. the internet is coming through my modem ARRIS CM550. My laptop is running windows 7 and recognizes the network...
Hello Hacker,
Open the lan card properties and open the tab configure. Go to the advance option and look for Link speed and Duplex option. From left pane choose the value 10Mbps/Half Duplex. The Lab connection will be enabled. Also enter the IP address and DNS settings if required.
Also visit the link provided below :
Jun 11, 2011 | NetGear FS605 - 5-Port 10/100 Network...
When my computer searches for new hardware, it recognizes it and then installs it as "Unknown Device" The device still will not work, however, because when I check it in the device manager it...
This device should be recognized automaticaly by the OS. There are some issues with Windows 7, though.
Make sure you are trying to plug it in a 2. USB port, rather than 1.1. This might cause you trouble (even though this will not be a problem if you have a new computer)
Connect the hub to the external powercord. Sometimes it is not recognized because the hub cannot drain enough energy from the port.
if you are using a desktop pc, make sure it is plugged in the rear usb ports and not at the ones up front.
refer to the manual for further assistance:
May 22, 2011 | Dynex 7-Port USB 2.0 Hub
I can not log onto my dell powerconnect 2708. I'm connecting the dell powerconnect 2708 into a hughes net modem and routing to three different locations. I would like to monitor/contol usage...
The problem you have is unlikely to be related to your server but to the modem and any ISP restrictions placed on your service i.e. it may block remote access or any port 80 traffic not originating from within your LAN. I don’t know much about your situation but it may be worth contacting your ISP to see if the functions you require are available with your hardware and contract type. Attached is a link that may help.
Jul 02, 2010 | Dell PowerConnect 2708 8-Port Gigabit...
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Have used my befw11s4 for a long time. Now, when
If you did tamper with the configuration and got it all wrong then use HTTP to access the router and set it to factory default. After that, power on the router, press and hold down the reset switch for about 3 seconds. That will help you out if there is no hardware problem.
Oct 21, 2009 | Linksys BEFW11S4 802.11b Wireless...
Slow internet problem i think its my communications card
This document is GENERIC for all types of PC using XP or before. Step 1: Detecting and removing spyware and adware software If the computer becomes slow when connecting to the Internet, your home page changes to a page you do not want, unwanted desktop links display, or advertising windows pop up repeatedly, then your computer probably has spyware, or adware installed. Spyware and adware can be difficult to remove manually. See the following HP support document for more information about spyware and how to remove it from your computer: HP and Compaq PCs - About Spyware, Adware, and Browser Hijacking Software . Step 2: Scan and remove viruses It might be that a virus or several viruses are attempting to use the Internet connection when the browser is open. See the following HP support document for more information about how to scan and remove viruses: Resolving and Preventing Viruses on Your Computer . NOTE: If you have not updated Windows recently using Windows Update (in English), now is a good time; after scanning and removing spyware and viruses . Step 3: Clearing history, temporary files, and resetting settings Clear the amount of temporary files that the browser uses as follows:
  1. Open the browser software.
  2. Click Tools from the menu bar.
  3. Select Internet Options . The Internet Options window displays. Figure 1: Internet Options windowc00162617.jpg
  4. Click the General tab.
  5. In the Temporary Internet Files area, click Delete Files .
  6. Select Delete all offline content , and click OK .
  7. In the History area, click Clear History , and click OK .
  8. Click the Security tab, and select Default Level .
  9. Click the Content tab, and click Clear SSL State .
  10. Click the Programs tab, and click Reset Web Settings .
  11. Click the Advanced tab, click Restore Defaults , and then click OK .
  12. Connect to the Internet. If the computer stops responding, continue to next step.
Step 4: Update the network or modem drivers Updating the network and modem drivers can fix some lockup problems. Install the latest update for your network hardware that you use. Update the network hardware if you connect to the Internet using DSL, Cable, or LAN. Update the modem software if you connect using dial-up.
  1. Go to the HP Software download page . Select your country/region.
  2. Type the model name for your HP or Compaq computer. For example, SR1820NX or m7434n.
  3. Select the version of Windows the computer is using.
  4. Select the network or modem driver update. For example, Realtek RTL8139 LAN Driver Update.
  5. Follow the instruction on the download page to download and install the update.
  6. When done, restart and try to connect to the Internet again. If the problem persists, continue to the next Step.
Step 5: Disabling Software that opens with Windows For troubleshooting purposes, reduce the amount of software that opens with Windows to try and find out if a software conflict is occurring. Open the Microsoft System Configuration software (Msconfig), remove the selection next to Load Startup Items , click OK , and restart the computer. For more information, see Preventing Programs from Opening When Windows Starts . Connect to the Internet. If the computer stops responding, continue to next step. Step 6: Removing and reinstalling ISP and Anti-virus software Remove the Internet Service Provider (ISP) software and install the latest version. Use the document on Advanced Modem Troubleshooting for more information about how to remove and reinstall the ISP software. Regards, Shrey
Sep 30, 2009 | HP 16-Port Ethernet Hub
Trying to hook up rotoer
no its usb. install the modem drivers on your pc and plug the modem in via usb.
May 20, 2009 | D-Link Desktop Switch DES-1105 5-Port
Setting up 16 port switch
Dear This is the step You can get a complete home network up and running in 10 easy steps. Here's a summary of what's involved: Take stock of your existing hardware. If you wish to share an Internet connection using Internet Connection Sharing (ICS), choose which computer will be your ICS host. Decide what type of network technology you wish to use. Make a list of the hardware you need for each computer. Install the network adaptors and install your modem on the ICS host computer. Physically cable the computers together. Switch on all computers, printers and other peripherals. Make sure the ICS host is connected to the Internet. Run the Network Setup Wizard on the ICS host. Run the Network Setup Wizard on the other computers on the network. Let's take that step by step. 1. Take stock of your hardware Note each computer's location and its hardware, including peripherals such as printers and modems. 2. Choose your ICS host If you wish to share an Internet connection between your computers using Internet Connection Sharing (ICS), choose which computer will be your ICS host. The ICS host has a direct connection, either by dial-up modem or high-speed link, to the Internet and provides access to the Internet for other computers on the network. Ideally, the host should be a computer running Windows XP. I'll assume you have made this choice in the following steps. Apart from XP's easy handling of ICS, by using an XP computer as your ICS host you get the benefits of using the Internet Connection Firewall. 3. Choose a network technology The most common choices are Ethernet and wireless LANs. For an Ethernet LAN you will need to install a network interface card, or NIC, in each computer and run cabling between the computers. If you don't like the idea of opening your computer to install a network card, look for a USB adaptor instead. Depending on the size of your network, you may also need a network hub or router to provide interconnection between PCs on the LAN. Two PCs can get by using an RJ-45 crossover cable; three or more computers require a hub or multi-speed hub (called a switch). If you have a high-speed Internet connection, a high-speed router is a good option. The Network Setup Wizard includes links to detailed advice about configuring your network, including help on designing a network layout to suit your home. If you opt for a wireless LAN, you'll also need a NIC for each PC (there are versions which use USB adaptors as well). The big benefit for home environments is that a wireless LAN does away with the need for cabling. On the down side, though, wireless LANs tend to be slower, less robust and appreciably more expensive than traditional Ethernet LANs. In particular, wireless LANs do not always live up to their stated working range, and you may find factors such as your home's construction and design, plus interference from other devices affect your wireless LAN's performance. You may need to add an expensive Access Point to extend the range of the LAN and, even so, it may not be sufficient. The bottom line is, if you decide to go the wireless route, make sure the store will refund your money if the LAN will not provide reliable performance within the specified range. 4. Make a list of hardware needed Make a list of the hardware you need for each computer, not forgetting any cabling, and buy it. If you're a little dazzled by the choices and configurations, consider purchasing a networking kit. These kits contain all you need to set up a two- or three-PC network. If possible, look for hardware which features the Windows XP Logo, indicating it is fully compatible with XP. 5. Install the adaptors Install the network adaptors and install your modem on the ICS host computer (you can also let the computers connect to the Internet independently by installing modems on each). 6. Cable the computers Physically cable the computers (and hubs or routers) together. Of course, you won't need to do this if you've chosen to go the wireless route. If you're installing an Ethernet network and have a lot of cabling work to do, you may prefer to get a professional to come in and do this work for you. It won't be cheap, but you can be sure you get the job done correctly and hopefully with minimal damage done to walls, ceilings and floors. 7. Switch it on Switch on all computers, printers and other peripherals. 8. Connect the ICS host Go to the ICS host computer and make sure it is connected to the Internet. 9. Run the Network Setup Wizard on the ICS host To run the Network Setup Wizard on the ICS host, click Start -> Control Panel -> Network And Internet Connections -> Setup Or Change Your Home Or Small Office Network. Follow the instructions in each screen and press Next to continue. XP's Network Setup Wizard takes much of the pain out of setting up a home network. The Network Setup Wizard will guide you through: Configuring your network adaptors (NICs). Configuring your computers to share a single Internet connection. Naming each computer. (Each computer requires a name to identify it on the network.) Sharing the Shared Files folder. Any files in this folder will be accessible to all computers on the network. Sharing printers. Installing the Internet Connection Firewall to guard you from online attacks. 10. Run the Network Setup Wizard on all computers To do so: Insert the Windows XP CD in the first computer's drive. When the XP Welcome Menu appears, click Perform Additional Tasks. Click Setup Home Or Small Office Networking and follow the prompts. Repeat steps 1 to 3 for each computer on your network. Make sure you maintain an active Internet connection on your host computer as you proceed through this process. geekgirl.tip If you don't have a CD-ROM drive on one of the network computers, you can run the Network Setup Wizard from a floppy disk: While running the Network Setup Wizard on the ICS host computer, select the option to copy the Network Setup Wizard to a floppy disk. Once you've completed setup on the ICS host, take the floppy to the next computer and insert it in the drive. Double-click My Computer. Double-click 3½ Floppy (A:). Double-click netsetup.exe. The quickie XP network If you want a really easy networking experience and you have the hardware to support it, consider clean installing Windows XP on two or more computers. First install your network hardware (network interface cards, cabling, et cetera), then perform a new installation of Windows XP. During installation, XP will sense your hardware setup, ask for a name for each computer, and then ask which type of setup you wish to create. Select Typical Settings For A Default Network Configuration. That's it. Provided your hardware is XP-compatible, XP will create a LAN using the workgroup name MSHOME. Using your network Once you have your network up and running, you can easily access other computers on the network via My Network Places (click Start -> My Network Places). The Task Pane in My Network Places lets you access computers on your network and adjust settings. The Task Pane in My Network Places lets you view your network connections and view each of the computers in your workgroup (the workgroup consists of all computers on a network which share the same workgroup name ? by default, XP gives all computers on your home network the workgroup name MSHOME, although you can change this if you wish). When you initially open My Network Places, you'll see icons for the Shared Files folder of each of the active network computers. Sharing a printer With your home network installed, your PC suddenly gains all the advantages of the other PC's on the network. If you've been lusting after your sister's colour photo printer, you can now print directly to it from your own machine. Provided, that is, your sister decides to share her printer. (You might offer to let her share your laser printer in return as an inducement ? sharing works both ways.) To share a printer, on the computer which is directly connected to the printer: Click Start -> Control Panel -> Printers And Other Hardware -> Printers And Faxes. (Note: These steps will be a little different if you're sharing a printer on a PC running a version of Windows other than XP. For example, under Windows Me, you click Start -> Settings -> Printers.) Click the printer you wish to share. Click Share This Printer in the Task Pane. In the printer's Properties dialog, click the Sharing tab. Click Share Name and OK. Make a printer accessible to others on the network by sharing it. Once a printer has been shared you can access it from other computers on the network. To do so: Click Start -> Control Panel -> Printers And Other Hardware. Click Add A Printer. In the Add New Printer wizard, when asked whether the printer is a local or network printer, select the latter. In the next screen, select the option to Browse For A Printer and click Next. Select the appropriate printer from the list and continue with the wizard. Sharing files and folders Sharing a folder is even easier than sharing a printer: Open a folder (such as My Documents), click Make A New Folder in the Task Pane and name your new folder. With the new folder highlighted, click Share This Folder. In the Sharing tab of the Properties dialog box, select Share This Folder On The Network. Provide a descriptive name for the folder. This name should make it easy for others on the network to recognise the folder; it doesn't have to be the same as the folder name you selected in step 1. You can let other people on the network view and edit your files or view them only. If you want to protect your files from tampering, remove the tick from Allow Other Users To Change My Files. There are a variety of ways to access a shared folder. Here's one way: Click Start -> My Network Places -> View Workgroup Computers. Click the computer whose files you wish to access and then click the shared folder. You can create shortcuts to shared folders to make them easier to gdfgf
Sep 08, 2007 | Networking Hubs & Switches
Acer (ALW-1123-A) Ethernet Switch (ALW1123A) Logo
47 people viewed this question
Top Acer Networking Hubs & Switches Experts
Jax Planet
Jax Planet
Brian Sullivan
Brian Sullivan
Are you an Acer Networking Hub and Switch Expert? Answer questions, earn points and help others
