Question about Acer Aspire 5500 5570-2609 Laptop
My screeeeeeeennnnnn ok well i turn it on and it goes through the normal setup but then the screen turns blue and it has some words on it but it shuts off too fast so i cant read it. and it just keeps doing that over and over and over again untill you press the power button.
  • Acer Master
  • 13,433 Answers
Yeah your windows seems to be messed up. You can disable automatic restart on error by pressing f8 on startup and selecting disable automatic restart. atleast now you will get the moment to read the text.
You can try repairconsole and do a chkdsk
if that fails try a repair install.
Posted on Feb 22, 2008
  • 52 Answers
Okay that sounds like the blue screen of death!try reinstalling windows and it should be okay ps have you got all the drivers for the sound card etc as well
Posted on Nov 03, 2007
Windows will not start up. Gives me windows start up option, but doesn't find a solution
Press and hold down the Delete key, power on, and this will start the BIOS setup, where you can choose the device to boot from. Usually a hard drive.
Dec 26, 2017 | Computers & Internet
Problem with windows starting up with blue screen
Update drivers that control your PC. If problem still persists then use a system utility tool like RegInOut, it will fix the following problems in your PC:
  • Application runtime errors
  • Windows crashes
  • Blue Screen of Death (BSOD)/ STOP Errors
  • Automatic system reboots
  • Failure to start your computer
  • Programs refuse to start
Hope it works for you.
Jan 03, 2012 | Coby 10" NBPC1023 Netbook PC
The Screen Turns Green then shuts itself off? Is this the Bulb or something else?
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. Adams01220@yahoo.com
Feb 13, 2011 | Sony KP-65WS500 65" Rear Projection...
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
When i turn it on it says run recommeded repair or run normal setup then when i run the repair it says hardware or software missing please select ok to shut down and when I run normal set it just goes back...
it's mean your operating system is failure so just do repair or format Ur OS & re install fresh copy of operating system..but take backup ur document before formatting Your OS.
Mar 25, 2010 | Toshiba Satellite Pro L300 Notebook
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
BLUE SCREEN THEN SHUTS OFF
cause: tuner i believe will cause tv to not find channels turn blue and turn itself off
Aug 18, 2008 | Sony KP-51WS500 51" Rear Projection...
Sanyo VPC-S7
if u want to take the date off all u need to do is to follow these steps
1)turn the camera on. then push the MENU button
2)once the menu screen has come up then go down to the words setup. then click OK to enter into the setup mode
3)Once your in the setup menu then go down to the words that say DATE STAMP then click the OK button and u will enter that
4)when in that it will have things like this YYYY MM DD
MM DD YYYY
DD MM YYYY
and lastly the word OFF will be there
scroll down to the word OFF and click the OK button. then u turn it of then bac on [if u want to test it out]
May 19, 2008 | Sanyo VPC-S7 Digital Camera
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
