Question about Karcher 2500 PSI Pressure Washer
Pull cord is locked. Was running fine and just
Pull cord is locked. Was running fine and just shut off...When I tried to restart, I could not pull the cord to start engine. Any ideas?
  • blueextc3221
    blueextc3221 May 11, 2010
    You have compression lock. Remove the sparkplug(s) or simply wait a few hours, and the pistons will seep pressure on their own.
    Problem Solver:
  • 8 Answers
Any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Posted on Jun 21, 2009
My pull cord won't release, to start engine.
if you cant pull it possible engine failure or debris in recoiler --check and inspect pull cord --remove plug and try to pull if engine turns it was air locked and should be able to start if locked solid have an internal failure -----if cord wont rewind return spring failure ,,rope jammed or debris
Jul 08, 2017 | Garden
Can't pull the start cord for my lawn mower. Any idea what I should try? Someone suggested wd40?
Cord is tangled or stuck in the starter assembly. Open it up and free it so you can pull and then have it retract back into the housing.
Mar 18, 2016 | Garden
125bt starts fine but once shut off will not restart for hours. always used proper gas oil mix. new spark plug runs fine next day
overheating add more oil pull muffler look at piston if scared up bad run till it locks up buy new one
Aug 19, 2014 | Garden
Simpson 2700 won't start with pull cord after running for a while?
Release the high pressure in the hose by triggering the wand as you try to restart the engine.
Jul 08, 2014 | Simpson Garden
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
My lawnmower which is a TORO 6.5hp-Tecumseh engine won't start. When I pull the cord the valves start to move but on the second pull it seems to sieze up and blow some vapor out the exhaust.It ran fine...
It sounds like hydraulic lock. The carb is dumping to much fuel into cylnder. Pull the plug when it feels locked up and pull again, if it blows gas out of the plug hole you have carb problem. Maybe needle is ****, maybe float has a hole in it and is sinking causing flooding.
Oct 11, 2010 | Toro Garden
Chain saw chain stopped moving
Was it running and shut down and was froze or when you went to restart it was frozen? Two things I have seen cause this other than a seized engine. One - chain bound up. Remove side cover and inspect chain mechanism. Two- the pull cord is bound up. Remove the pull cord cover and inspect.
Jun 15, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
3,098 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
