Question about Milwaukee Tool 10" Magnum Compound Miter Saw
Miter saw motor is running back wards
I have a milwaukee miter saw I put in new blade and find motor was running backwards . When I put blade in right the wood just smokes .
I,ve had this saw for over 10 yrs
JM
  • 1 more comment
  • masterj45 Jun 22, 2009
    After some asked if I did any wire ring . At I thought no . Then I rembered I did put a new cord in . I know now I must have reversed a wire .Thanks for joging my mined. Well let you all know if that was it
    Thanks jerry
  • Dean
    Dean May 11, 2010
    Unusual for motor to start running backwards after 10 years... in fact almost impossible! Are you sure you have the blade installed in the right way? The teeth should be facing the back of the saw.
  • steamman27 May 11, 2010
    MOTOR STARTING CAPACITOR MAY BE SHOT. CHECK WITH MANUFACTURER
    ABOUT PROBLEM ON THE INTERNET.
  • 34 Answers
DON'T BE SURPRISED IF THE MOTOR STILL RUNS BACKWARDS. YOU CANNOT REVERSE AN
AC MOTOR BY REVERSING THE POWER WIRE CONNECTIONS.
Posted on Jun 22, 2009
  • 285 Answers
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Milwaukee magnum miter saw blade change
See page 9 of this manual: http://documents.milwaukeetool.com/58-14-6955d3.pdf.
The manual is for a 12 inch saw, but the instructions will be similar. UNPLUG THE SAW FIRST!
May 10, 2014 | Milwaukee Tool 10" Magnum Compound Miter...
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
Will not cut 45 miter cuts perfect
Possible but I would think not likely
Try this
Put a new blade on
Set a magnet on the table or fence with phillips screw driver stuck to it
Slide the point of the screw driver up to within 1/16" from the blade just above the teeth
Run the unplugged saw by hand and watch for any side to side movement of the blade
Can you move the blade up and down or side to side?
If everything seems normal the plug the saw in and run it again watching the screwdriver
Please be careful don't allow the screw driver to contact the blade at high speed you will create a bullet
Mar 10, 2010 | Porter Cable Cable 12" Compound Laser...
Motor on miter saw is runnig back wards
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
May 02, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Putting on a saw blade
Well M8:) try to to unloose it backwards, It dosent loose as usal, you need to posh the otherway. Nornaly you loose things from right to left, this one (and other items that cut) you loos from left to right.
Good luck to you
Dec 18, 2008 | Bosch 12" Compound Miter Saw 3912
Milwaukee Tool 10" Magnum Compound Miter Saw Logo
276 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
