Question about IBM ThinkPad T60 Notebook
Startup problem system bios shadowed and video shadowed as well. bad crc1 post command screen also keeps flashing black...
  • 1 more comment
  • matt6147 Jun 22, 2009
    SCREEN FLASHES A F T E R IT BOOTS INTO WINDOWS, AND AFTER IT DISPLAYS AFOREMENTIONED BAD COMMAND CRC1 MESSAGE, BIOS SHADOWED AND VIDEOCAM SHADOWED AS WELL
    I CANNOT EVEN GET IT TO GO INTO THE BIOS AREA, TO SELECT THE "DEFAULT VALUES"... IT JUST STAYS ON THE "ENTERING SETUP" SCREEN...
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    not sure i understand, are you having a problem with a dim screen, does the system ever boot into windows? When does the screen flash? When you first turn on the laptop or after it trys to boot up into windows?
  • 244 Answers
Go into BIOS and select Default values.
That should take care of the problem
Please let us know how it goes.
Don't forget to rate
Posted on Jun 21, 2009
Error 0175: Bad CRC1, stop post task
ERROR
0175: BAD CRC1, STOP POST TASK.
Firstly, this error is generated due to a couple of different reasons. First, there may actually be a problem with the power circuitry and the CRC function is actually doing it's job reporting the error. There are several tests you can perform to tell if this is the case with your system.
Secondly, this bad CRC error can be generated by sudden power loss to the system, especially if the system loses power during boot up or POST process. Both mean that there could be a problem with the motherboard and it needs replacing.
Try the steps below to determine what is wrong.
1) Start the system and watch the status lights in the LCD hinge or near the power button. They should flash once (some models twice) before the system shows a display. If they flash 3 times or more, you have a power problem.
2) Start the system and allow it to reach the CRC "stop post task" error message. Let it sit at this error for several hours. The system should sit at this error for ever or until user intervention occurs.
3) Some things to watch for while the system is sitting at the CRC error and running for several hours would be: Screen going black, System rebooting, System powering off, ect.. ect.. ANY activity by the system is a warning that power problems exist in the system.
4) Try restarting the system several times consecutively, shut the system down by holding the power button for 5 seconds, then restart keeping an eye on the status lights for any additional flickers.
All the above tests should be done with AC power applied and battery installed. Also ALL drives installed.
Regards.
Jan 19, 2011 | IBM ThinkPad T23 2647 Notebook
ERROR 0175: Bad CRC1, stop POST task message Been using my IBM a30 laptop for some months but was surprised to get this error when i tried putting it on this message pops up ERROR 0175:BAD CRC1 STOP POST...
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Jan 11, 2010 | IBM ThinkPad A30 Notebook
ERROR 0175 BAD CRC1 COMMAND STOP POST TASK
the crc is the cyclic redundance check your bios is corrupt. you will need to flash the bios to bring it back the internal bios bottery will need to be removed for 1 min then replace. it should bring it back if not you bios chip has burnt out. i have never replaced a bios chip but you will have to find one to replace it
Jun 24, 2009 | IBM ThinkPad T60 Notebook
Error 0175 bad crc1
Numeric error codes - ThinkPad General From IBM Web Site
Notes:
· The most likely cause is listed first.
· A numeric error is displayed for each error detected in POST or system operation.
· In the displays, n can be any number
Error code
Symptom or error
Field replaceable unit or action, in sequence
0175
Bad CRC1, stop POST task. The EEPROM checksum is not correct
This problem you may not be able to fix. There are a couple of things you can try.
1st Keep on rebooting your laptop until this error goes away.
2nd Replace the BIOS battery, it maybe nearly worn out. After replacement you need to go into the BIOS setting to set the Date & Time.
System board
May 16, 2009 | IBM ThinkPad T20 2647 Notebook
CRC Problem
Chances are since the system CRC1'd it has a very old BIOS revision. From version 1.10 on, the CRC issue has been fixed. So, get the latest BIOS from IBM, T21 BIOS: ftp://ftp.software.ibm.com/pc/pccbbs/mobiles/spsdkz34.exe and flash the BIOS. Reboot the system and verify the updated BIOS. Now power down the system, desolder the known good EEPROM and resolder the CRC1 EEPROM. Boot the machine and hit ESC when the splash screen comes up and watch the post screen. The new BIOS should have recalculated the EEPROM checksum and written the changes to it. You'll know if it worked because the CRC1 error will be gone.
Jan 03, 2009 | IBM (09N5424) Motherboard
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Toshiba Satellite M45-S169 won't boot
you must restore your bios settings to the correct ones. contact toshiba customer support for the correct toshiba settings.
Jul 27, 2008 | Toshiba Satellite M45-S169 Notebook
IBM ThinkPad T60 Notebook Logo
333 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
