Nintendo DS Console Logo
Posted on Jun 21, 2009
I have the regular nintendo ds.Oneday i go turn it on and screen
I have the regular nintendo ds.Oneday i go turn it on and the entire top screen is white blank
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2314
Points
11
Did it maybe fall when you did/didnt notice if so then didi it fall on a hard suface if so then you broke it they best thing is to either fix it by yourself*BIG RISK* or get a new one
1helpful
I'm trying to replace a Nintendo DS Lite ribbon cable to the top screen. I've heard that you have to replace the entire top screen. Is it possible that you can buy another ribbon cable instead of another...
Naa got to get a top screen they come with the ribbon cable no way around it they are cheap have a look on ebay u can get them for abt $10 delivered
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
1helpful
Nintendo ds lite top screen has lines
sounds like possibly the ribbon, should get it checked incase it dies for good.
2helpful
2answers
DS Lite Turns off when moving top screen.
ITS AN INTERMITTENT CONTACT with the ribbon belt that connects from the main unit to the upper screen , I believe you need to take the DS for an authorized repair shop, but before doing anything , give a call to a tech support at NINTENDO , THEY would gladly help you out and inform you whats the next step , hope this helps , AJ , in case you dont have the LINK, let me give it to you : http://www.nintendo.com/consumer/ ,
hope this helps AJ
3answers
Screens not Working!!!
I'LL SAY ITS BROKEN YOU NEED TO REPLACE IT
The top ds screen
Time to use your ultimate majestic warranty now
Nicholas
10helpful
4answers
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Ds top screen half normal half green tint
i had the same problem  but it was blue tint shortly after the ds would turn on flash then turn off turned out to be the wire ribbon to top screen:: needed new top screen!!
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
