Question about Kenmore 55603 Side by Side Refrigerator
Kenmore runs all the time
MIne runs all the time but and everything is frozen but it will not stop running I have unplugged it cleaned it and it still keeps running everything is super cold! not sure what to do.
  • sailoff
    sailoff Jun 21, 2009
    I can replace the thermostat not a problem but I went back out there and I tapped on the temp gauge and it stopped running so going to try to clean the contacts in there first with the air compressor see if there is dirt in the contacts. Then if that fails I will get a new thermostat the freezer is in a wood shop so it gets real dusty!
  • blueextc3221
    blueextc3221 May 11, 2010
    Your thermostat has failed - please reply with the exact model # if you require additional help.
    President:
  • 1,136 Answers
Hi, Make sure you controls are at factory settings. Both controls should be at half of whatever is on the dial.
You should also check the freezer temp and it should read 0 to 5 above zero. If the freezer is holding this temp, the fresh food side should be 34 to 38.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on Jun 21, 2009
My dryer will run until have to stop it then it will not start the cycle
will it start an hour later? then bad motor windings
Aug 02, 2014 | Kenmore Dryers
Lg electric range oven touchpad buttons not working
Did they stop working after running the self-cleaning cycle? That is what happened to mine. I moved the oven and unplugged it. Left it unplugged for a few days waiting for repairman. He plugged it in when he got there, and everything worked. He advised against using the self-cleaning cycle because the heat can cause problems with the touchpad buttons.
Jul 04, 2014 | LG LRE30451 Electric Kitchen Range
I have a G E TFX20Jr side by side it runs all the time, everything works fine. My eggs are frozen in the firg. side. What is my most likely prob?
Sounds like a thermostat stuck. Clean condenser and check any fans are running fine. If turning the thermostat down stops it running all the time, all the better!
Nov 15, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Refridgerator appx 5years old, everything runs properly but does not get cold. It also runs all the time.
is the freezer at temp, meaning is everything in the freezer frozen? if so, it sounds like you have a defrost problem. is there heavy frost and ice one the back wall of the freezer? if so its a defrost problem. bad defrost thermostat, timer, or heater
Jan 02, 2009 | Refrigerators
RUNS ALL THE TIME
Hello, I hav no idea of what type of machine you are using but, I have two older Kenmore mechanical sewing machines and a very old Dressmaker and have fixed the same problem with mine.
If you gently remove the outer metal housing on your pressure foot control, (unplug it from both the outlet and the machine) there is a black metal coil like thing with two longer end pieces. They respond to your foot pressure, tranferring that pressure to a series of parts and copper to complete the electrical connection needed to run your machine.
Look and see if there is any rust around that black coil piece. If this is the problem, your pressure foot is getting caught and frozen in the "on" position and unable to dis-engage to stop the electrical connection to your sewing machine.
Clean any rust, (emery or steel wool works for me) check your wire connections, dry it completely and replace the foot petal housing. It may take a little tinkering but this will work if this is the problem. Best Wishes.
Dec 08, 2008 | Sewing Machines
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Modle 80 washer question?
ck motor wiring connection for burnt or dark connections also possible bad timer ..have known timer to cause motor to run both speeds at same time this causes motor to overheat and shut off
Aug 16, 2008 | Kenmore 22422 Top Load Washer
Freezer runs all the time
sound like a plugged drain if you have ice building up on the bottom ..defrost the whole freezer and clean out the drain. you may have other problems too
krazytech
Apr 05, 2008 | Refrigerators
Runs 90 percent of the time Kenmore s/s 57262791
Hello! panda1,
You are fine, if all is working, just leave it, and enjoy it.
Problelms that may arise: After adjustments, ice cream to soft; milk to warm, vegetables frozen, eggs frozen, temperature not controlled. Typical of this units.
Since this is a energy saving unit, It tends to use more energy being that the compressor is low rated. The evaporator fan runs a lot, the defrost cycles run multiple of times, noisy, grumbles, and can keep you awake, if one keeps a ear to it. Just forget it. Once in a while, look at the bottom of the freezer, move some items, look at the coil , in back, an see if there is any ice build up, Some is ok. It should be clean, clear after a defrost cycle. (See input from peyton32034) may be additionally useful.. Regards, fmauka
Dec 23, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Everything in frig is frozen and it won't turn off.
If the compressor is running non-stop then the temp. control is not telling it that it's "cold enough". If the compressor isn't running non-stop then you should look at the air damper (little window) that lets the freezer air into the refer compartment... if it's stuck open then you will always get cold air pushed into the fridge eventually becoming a freezer in itself.
Jan 17, 2007 | Kenmore 74844 / 74842 Top Freezer...
Kenmore 55603 Side by Side Refrigerator Logo
344 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
