Question about Craftsman Garden
Brand new honda lawnmower starts and runs fine then backfires
My new honda motor lawnmower will start and runs fine then it will starts to sputter and back fire.  then stops.  spark plug is getting carbon on it.
  • Cameron loker Jun 21, 2009
    no I don't know very much about carbs
  • Jim Parker
    Jim Parker May 11, 2010
    Have you tried adjusting the H & L screws?
    Jim
  • 1,041 Answers
There should be 1 or 2 screws on the carb. You will probably have to remove the air breather to get to the screw(s). I've been seeing a lot of these types of questions, new equipment not running properly. Factory settings were not set properly.
When you find the screw(s), screw in a clockwise direction until it stops; DON'T SCREW DOWN TIGHT, JUST UNTIL IT STOPS. Then unscrew counter clockwise 1 1/4 turns. Try starting.
Continue this process, 1/4 turn at a time up to 2 1/2 full turns. If you forget where you are at on the turning process, start over by screwing back down. Then pick up process where you left off.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 23, 2009
    If you decide not to attempt to adjust the carb., then Maybe it would be a good idea to take it back to where you bought it. They should make it right since it's brand new.
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
I have a Miller blue star 3500 with electric start Honda engine.
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Dec 27, 2016 | Miller Welding Tools
Why won't my Honda HRX217VLA lawn mower start
Hi Duane:
I'd be thinking that it's possible that the alignment key on the flywheel has sheared. That will throw the timing out and it can't run.
Fix is pretty straightforward.
Disconnect and remove pieces until you have the flywheel exposed. Loosen the nut. Lift on the flywheel and smack down on the nut with a plastic mallett to loosen the flywheel. Then remove the nut and flywheel. Replace the key (get replacement ant any lawnmower or chainsaw service shop)
Put it back together and it should run just fine.
Cheers.
Nov 04, 2015 | Honda HRX217VKA Lawnmower
After start it backfires, sputters then runs
Hi,when starting bike you put the chock on,remeber this is to make a richer mixture for cold start,so when you start the bike put put the choke off a little bit as it warms up,other wise wat you are doing is couseing it to floud,so again as the bike warms up put the choke off little bit at a time,all the best.
Sep 01, 2015 | Honda VT 1100 C2 Shadow Sabre Motorcycles
2005 Honda Shadow Spirit (750) hesitant and sputtering upon first spring ride. Thoughts?
Just sounds like either a jet is blocked in one of the carbs or maybe a spark plug is fouled up.tap the exhaust down pipes with your hand quickly to see which one isn't getting hot to see which ones not running.
Apr 11, 2015 | Honda Motorcycles
4.3l backfires through throttle body
check the firing order as it indicates 2 wires crossed
Jun 30, 2017 | 2000 Chevrolet Blazer
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Lawnmower has trouble starting, but runs
Hello. Did you replace the air filter? If not check it and replace it if it is dirty. Finally get a carbeurator cleaner such as seafoam which you add to the fuel at the rate of one ounce per gallon. This will get the inside of your carbeurator cleaned up. Do these things and you should be back in business.
Jun 20, 2009 | Garden
Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Mar 21, 2009 | THQ The Lawnmower Man
Garden Logo
1,508 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
