Question about Sewing Machines
Trying to fit the bobbin onto the shuttle of a Necchi 524 FB. I have instructions for a Necchi 524, but the FB is a little different. I can't find a place to latch the bobbin to.
  • Anonymous Mar 14, 2014
    I want to tell if the needle and bottom hook have proper timing. How do you tell?
My Necchi sewing machine-model #534FB will not sew.
perhaps the hand wheel clutch need tightened .
Mar 03, 2018 | Necchi Sewing Machines
Necchi 3537 manual is useless. How do I put bobbin shuttle hook back into the machine?
HINT: before you install the shuttle, make sure to place a drop of sewing machine oil around the outer edge of the shuttle and lightly spread it around the outer edge (you should do this about every time you change a bobbin). Sorry, you'll probably need to be familiar with removing and installing the shuttle. Have patience! Once you've done it a couple of times, you'll wonder why it was so difficult.
It usually helps if you can tilt the machine back about 45 degrees so it is supported by something (pillow, cushion) so you can get good visibility into the bobbin area.
Raise the needle so that the take-up bar is at its highest point.
Make sure the outer hinged door on the shuttle area is open. Inside that open door is a metal unit that is shaped like a "C". The shuttle makes up the other part of the "C". The two C's face each other and complete the circle. Grasp the shuttle by the projecting bobbin pin. (Perhaps the photo & videos will help you in placing the shuttle (you'll probably need to wiggle it around a little until it pops into place.) Once the shuttle has snapped into place and you've closed and latched the outer cover, you can install the bobbin case.
Necchi Zig Zag Shuttle movement
Necchi Oscillating Shuttle
Jan 04, 2016 | Necchi Sewing Machines
Why does'n the needle catch the bobbin thread on Necchi BU Nova
Your hook is moving correctly. Not all machines do a continuous circle. If it's not catching the thread, the timing is off. It's a great machine, and worth every penny to have it serviced.
Feb 27, 2015 | Singer Sewing Machines
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
How do I put the bobbin in
try this link for a manual and the information should be in it Necchi 3101 FA 3102 FB Instruction Manual
Jul 09, 2014 | Necchi 3102 Mechanical Sewing Machine
Trying to sew straight stitch but stitch loose and lots of thread on bottom
No top tension, follow manual to thread top again and make sure tension dial is set to 5 and thread is pulled between the tension discs fully.
May 21, 2010 | Singer 57815 Mechanical Sewing Machine
Problem inserting bobbin
Inserting bobbin into the bobbin case or problem inserting bobbin case into the shuttle?
Make sure the thread will feed from the bobbin clockwise and through the guide on the bobbin case.
Lift the lever on the bobbin case to hold the bobbin in place as you inset the bobbin case into the shuttle.
If the bobbin case for this machine as a "finger", this has to align with the opening in the shuttle.
If you cannot readily see this - move the bobbin case a bit to the left and right until it clicks into place.
Feb 20, 2010 | Necchi 6018 Mechanical Sewing Machine
Sewing Machines Logo
206 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
