I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
If you open the set you can find a battery pack which is mae for the panasonic shaver. But for replacement you can put along the available ones inthe market by looking at the voltage and amperage. The curent (amp) factor is most important as this is what drives the motor for the time period.
There are also many models of the AAA or AA that can be suited to fit the space to give this VA rating.
