Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Set up to match my television and remote control
I have a panasonic DMR-EZ47V DVD recorder, and am trying to use its remote control to operate my NEC LCD TV model NLT-22HDB3. In the panasonic operating instructions page 20 it says to hold down the "Turn TV on/off "and enter the code, which for NEC is shown as 36. I have done this and it does not work, and was wondering if there was another number applicable to this TV?
  • 1142 Answers
SOURCE: How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
Posted on Jan 31, 2008
  • 1019 Answers
SOURCE: Panasonic DVD Recorder DMR-EX77
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Posted on Mar 17, 2008
SOURCE: Instruction Manual for Panasonic DMR-EZ47V
Heres is the manual link.
Posted on Dec 28, 2008
SOURCE: need a instruction manual for a panasonic DMR-EZ47V
I need an instruction manual for DMR-EZ47V.
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: Panasonic DMR-85H remote non-responsive
Press and hold 1 and enter on the remote for 2-3 sec's the remote will be on 1. If you need 2 or 3 do the samething,
Posted on Feb 23, 2009
  • 50 Answers
Here is the english manual..
Use a pdf reader to open the file..
Posted on May 30, 2009
0 characters
1 Points
Operating a panasonic dmr-ez47v without a remote control
Many DVD recorders need the remote for a few functions like menu and setup. The remote part # is EUR7659T80 in the US. You can order parts here . it costs about $35 US. Save yourself some headaches.
Feb 21, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have accidently messed with the settings for the remote control, and now, even...
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down buttons at the same time until it says "Bye" on the display. When it shows the clock it is off - wait a few seconds then turn it back on - you should see the initial setup asking you to choose a language.
Note: You may have to flip down part of the front panel to reveal the channel buttons.
on Apr 29, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote not responding
Are you holding enter and channel number at the same time for about 2-5 seconds
Aug 05, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote control
re-sync remote by pressing "enter"/"OK" while holding number "1" or "2" or "3" - the proper number should be displaying on unit as RC1, RC2, or RC3
Mar 31, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can you tell me the Full Model number for this TV Please
Jun 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
330 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
