Question about White Sewing 1409 Mechanical Sewing Machine
Sewing machine fabric won't move - White Sewing 1409 Mechanical Sewing Machine
  • 30 Answers
It could be that your feed dogs are lowered. Look for a knob with 2 positions; one with a zig-zag and dotted line next to it, and the other with a cross-hatch design.
Posted on Jun 22, 2009
bargainbox
  • 1388 Answers
SOURCE: Kenmore sewing machine # 385.17626
Check your stitch length regulator is not set on zero.
Remove the needleplate and clean out any lint from between teeth of feeddogs......while you are at it, clean around the bobbin area and remove any lint under bobbin case.
Posted on Jun 22, 2008
  • 14 Answers
SOURCE: ELNA 7000 SEWING MACHINE
If you bend over the front of the machine, you will see a slider switch on the back of the machine, and there is a small "button" at the bottom right of the switch (your right). If you push this button down, you can slide the slider switch to your right and the feed dogs will go up.
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: Brother XL-6562 sewing machine is not feeding fabric through properly
Oil might help but it sounds like you don't have enough pressure on the foot. You can take the casing off where the light is and there is a screw back there that controls the tension on the pressure foot. It is not meant to be changed by anyone but a professional. I've changed the tension but it wasn't easy. If you are still interested let me know and I will try to explain.
Posted on May 21, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
hi , i am looking for needles for the juki ddl 555 industrial machine , any ideas
thanks
Posted on Jan 20, 2010
Dressmaker sewing machine 7000 thread won't move
something could be wrong with the feed dogs, it's would be a
good idea to have them checked.
Jan 08, 2013 | Sewing Machines
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
I have a JukiLU562 and fabric won't move starting to sew
the feed dogs are what move the fabric thru the machine to sew it
if the feed dogs are not working, then they need to be checked
to see if they have some loose or broken or need to be retimed
Jun 05, 2012 | Juki Sewing Machines
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
When sewing, the thread keeps pulling the fabric threads and the result looks messy. I've tried playing with the thread tension but it won't help.
have you tried using a new needle- if the needle is the slightest bet bent or or damaged it can cause problem with the fabric threads
if the needle is not the correct one for the fabric, it can move or damage the fabric threads
also clean under the needle plate for loose threads or lint also in the bobbin area
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
CI just got my sewing maching six month ago and now for the first time it giving me problem . whenever im sewing the fabric won't move please please !!! help me to fix the problem.
in the needle plate area you'll find the feed dogs, they move the fabric forward as you sew, they should be up to sew . most sewing machine have a lever or knob that can be moved to change the feed dog position, unless then knob is broken
Aug 04, 2011 | Sewing Machines
White Sewing 1409 Mechanical Sewing Machine Logo
231 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
