Question about ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Can't Install Windows
Computer boots up to Windows CD. It says "Inspecting your computer hardware" then the screen goes blank and never continues. Any ideas?
  • 208 Answers
Try one ram stick at a time. take out any extra usb devices not needed and pci too. try minimum. if not try burn the iso in zip with and test memory.
Posted on Nov 03, 2007
Pavilion dv3 power on and off continous and screen blank
Computer Keeps Rebooting - cannot access Safe Mode
1. Boot up with Windows installation CD 2. It will give you the option to use RECOVERY CONSOLE 3. Type chkdsk to check disk - this fixes bad blocks and moves data to another area. 4. When completed, remove Windows installation CD and reboot computer
Mar 01, 2013 | HP Pavilion Dv3-1075us Notebook
It is not starting up
Good day. I suggest for you to reinstall windows and use the repair options. Usually software encounter errors or some files might get corrupted causing your computer not to boot up properly. The repair option in Windows XP will help you to fix those issue. here are the steps to follow:
1. Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
2. Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
3. Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD.
4. A blue screen will appear and begin loading Windows XP Setup from the CD.
5. When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
6. Then press F8 to continue
7. Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
8. Then just choose repair option to repair your Windows Xp
9 Then it should work. If iin any case that will not solve the issue, you might try to install fresh copy on Windows Xp
Hope this information will help you resolve your issue. Have a great day.
May 24, 2011 | Microsoft Windows XP Home Edition
My computer, a lenovo y510 laptop malfunctioned. After inserting the recovery, and attempting to boot from the disk, the screen simply goes blank instead of opening the normal vista install center.
Hi lightning_ha,
Based on your situation, I suggest trying the following steps:
1. Turn on the system then insert the recovery disk inside the ODD.
2. Now turn off the computer while recovery disk is inside.
3. Turn on the computer, the moment you press the power button, immediately tap the F12 key and press it continuously.
4. Now you have the boot option. Select CD/DVD/ODD by pressing enter then continuously tap it until you see the Windows is loading a file.
5. Wait until it goes 100%.
6. Now it will ask you on what partition you will put the operating system. Just select the partition that has a large capacity or size.
7. Just wait until it completes the whole installation.
8. Restart the computer.
Hope it helps,
Thank you for using FixYa.
Oct 06, 2010 | Lenovo IdeaPad Y510 Notebook
How to re-install windows xp?
all you need windows cd installer, insert and make cd drive as first boot, follow on screen and you can select either to format or leave existing file. continue and follow all instruction on screen.
Apr 29, 2010 | Microsoft Windows XP Professional With...
While installing windows xp monitor went blank, cd started to blink and would not open. I was useing a crt monitor at the time due to the fact thats alli had. HELP, what's wrong
Turn off the computer. Try unseating and reseating the memory one stick at a time in each slot one at a time. After each reseat of the memory try turning on the computer and see if you get video back on the screen.
If not then try another monitor. If all that doesn't get video back on the screen then the motherboard is bad in the computer.
Nov 26, 2009 | Dell Computers & Internet
When i turn on my lap top which is a dell 1525 Inspiron it goes as far as putting your password in and from there it goes straight to a blue screeen and nothing else comes on the screen after that.
just open spare the parts then u can do the foolowing things
plug ot the battery for 10 minutes
if it does working there is an extra another find it do as that
if it is not workable u did want gone for customer care for dell company
Jul 16, 2009 | Dell Inspiron 1525 Notebook
Laptop boots up but after nothing.
Hard drive is shot. replace and then re install operating system
Jul 05, 2009 | Toshiba Satellite M45-S265 Notebook
Acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Jan 31, 2009 | Acer Aspire 7720 Notebook PC
Blank Black Screen After Windows XP Loading Page
the easiest solution would be to re-install windows and hope it is not a hardware problem
Jan 12, 2009 | Dell Dimension 2400 PC Desktop
Xp boots and hang up on blank screen
Insert the original Windows XP "System Restore" CD-ROM,
and tell your computer to "boot" from it.
Does it boot, and get to a screen that asks you "do you really want to ...", or does it stop at a "blank" screen?
If it "stops", you have a "hardware" problem.
If it "asks", then either:
* your disk-drive has failed, or is about to fail,
* your installed copy of Windows is messed-up, and it cannot complete the "boot" process.
Take your computer to a computer-store, for more trouble-shooting.
Aug 28, 2008 | Computers & Internet
ASUS A8V-VM SE (MB-A8VVMSE) Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
