Question about Whirlpool GEW9250 Electric Dryer
I have a problem with the button on my simpson eziloader 4k dryer
I have a Simpson 4kg dryer - model Eziloader 39P400. I close the door but I cannot push the button in properly to make it start. This has happened before and I thought it may be the door slipping so jiggled it around and it worked. But this time I cannot press the button to start the dryer.
5 Suggested Answers
SOURCE: Dryer won't start, Simpson Eziloader 4kg
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
Posted on Jan 25, 2008
dmftrucker
  • 1922 Answers
SOURCE: dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Posted on Jul 30, 2009
  • 93 Answers
SOURCE: how to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Posted on Aug 29, 2009
  • 3074 Answers
SOURCE: simpson 5kg eziloader drier was
check on the motor for a reset button
Posted on Oct 30, 2010
Small condencer on my 39P400 has two coloured wires red &blue which wire goes onto what pole ??
Either way around it doesn't matter. Unless it is marked with a P & N or + & - then red would go to P or +
Jun 15, 2017 | Simpson Washing Machines
We have put a new belt and bearing on my 4kg Simpson eziloader dryer and spring is in place it works for a while and then the belt comes off again what could the problem be
I would check the pulley on the motor, and the belt tensioner that the belt winds through. My initial thought is that when installing the belt onto the tensioner it may have been bent. GOOD LUCK FRIEND.
Nov 16, 2014 | Dryers
Hi I have a Simpson 4kg eziloader dryer that keeps tripping the power mains . Would this be the timer ?
The heating element uses the most power. Was the home wired by a licensed election ( the dryer plug)? if it was it should have #8 or #10 wire depending on the load. the breaker is sized to the wire (so don't change it). you may have a clogged vent pipe. this will reduce air flow and make the dryer work harder possibly tripping the breaker. You should probably start by making sure you vent is clear and free from debris, debris in the vent could cause a fire.
Sep 10, 2014 | Dryers
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
I have a simpson 39p400
The start switch itself apparently has broken internally. Try replacing the switch.
May 21, 2012 | Dryers
Hello My simpson Eziloader Dryer will not spin I replaced the drum belt but still not fixed, if I turn it manually and close the door really quicly it will start turning but then stops soon after. Please...
need the cap replacing,........... should ba a silver can shaped cap. sited next to the motor
. it will have 2 or 4 wires connected at the top......................
cheers
Mar 24, 2011 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
Broken main belt.
Aug 29, 2009 | Dryers
Dryer will not spin
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
349 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
