Question about RIM BlackBerry Curve 8310 Smartphone
I just purchased my Blackberry yesterday and now the keypad wont work but the trackball will still move around what is wrong with it
  • 34 Answers
It is about keypad connecter which is not properly fitted
Posted on Jun 21, 2009
Blackberry trackball wont work
I have the Blackberry Tour.......I work in all kinds of environments....so I get dust, dirt, and debris in my trackball......every 3-4 weeks I cannot move the trackball.......all you gotta do is get AIR DUSTER, the same you use for your computer keyboard etc. and keep it about 3-4 inches away and spray the air at your trackball and move it around......just keep spraying it for about 1-2 seconds at a time and move the ball around after every spray and you are good to go!!!!!
Nov 09, 2009 | Lands Phones
My keys dont work I cant read text or answer calls help. I can see my screen when I first plug it in to charger. Ican move trackball but it wont let me open the icons. My phone rings when i push the button...
it seems you have drop waterto your keypad you must making dry first after that disasembly blackberry casing and keypad and brush it with toothbrush and alkohol 100 %
Aug 21, 2009 | Microsoft Office Outlook 2003 for PC
The speedball wont move to the left
Your trackball is damaged you need to get a replacement for it or you can pop it out and see if anything is just shifted out of place in that case you can just shift it back into place and carefully put it back in and then it should work just fine.
Kyle
Jun 04, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
The tracking ball rotates but it does not move over the icons on the left side. Is there anything I can do to fix this?
Depending on how comfortable you are with removing the trackball it's not hard to fix... you may have some dirt or grit interfering with the trackball and/or sensors. Take a small screwdriver or blade and gently pop the silver ring around the trackball off. This will free the actual trackball housing. Use an old toothbrush to clean everything. I also soaked the trackball in a little rubbing alcohol. Just make sure it is completely dry before reassembling. If that doesn't work you can purchase replacement trackballs from places like crackberry.com.
Apr 18, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
The track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
Mar 13, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have blackberry pearl and the white roller does not move downwords
I had the same problem and after being told that the sensor was more than likely fried and that I could "upgrade" with the purchase of a new phone I tried to "clean" the sensor myself. I used a can of "Dust Off" )compressed air that you use to clean your keyboard) - shooting the keyboard of the phone from various angles and it did the trick. Good luck!
Dec 30, 2008 | Verizon Communications BlackBerry Pearl...
Bb8800 the pearl/cursor does not scroll up
This is usally caused by the trackball getting dirty.
Oct 12, 2008 | RIM BlackBerry 8800
Blackberry 8310 keypad locked
Use a blowdryer of the keypad for about a minute, some buttons will start to work. Continue until all of the buttons are functional. Works like a charm.
Jul 05, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
66 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
