Question about Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
Kenmore 80 series electric dryer model #110.67832791
Dryer runs for 5 minutes or so and shuts off completely. Doesn't start again for an hour so and even then runs for 5 minutes and shuts off. Heat stays on while motor is running, but shuts off when motor does. Dryer vents and even dryer is lint free (already disassembled, removed drum), belts and pulleys/wheels (that support drum) are fine.
  • 3 more comments
  • mendi Jun 21, 2009
    I haven't tried rotating drum while holding start button. But when it stops and I push the start button, there is no noise as if it's dead or plugged off. I can restart after a while (shortest time I tried is an hour), but same thing happens again.
    Thanks, I will check as you suggested and inform. And I'm sure door switch is not the issue.
  • mendi Jul 05, 2009
    It's been a while to the test the dryer.
    When motor is acting up, there is 120V between red and black wires. It sounds like motor is getting power, but isn't going to run, i.e, it has gone bad.
    How do I test thermal overload switch, just to make sure it is the bad motor? Where is it located?
  • mendi Jul 06, 2009
  • Anonymous Mar 18, 2014
    Kenmore 700 series 110.67741600 Dryer runs fine with air dry(no heat) with heat shuts down in a few minutes, it heats up ok, in fact I wonder if it really is overheated, I'm not sure, then just shuts down, I disassembled the entire machine and removed every spec of dust, in the motor, in the vents - no change
  • 530 Answers
When you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
  • erica graber Jun 21, 2009
    the only thing that would make sense to me is that your thermal overload in your motor has tripped. you have a belt switch i believe it has 2 blue wires going to it check and see if you hear a click sound when you let the belt pulley down. If you can run the dryer and check voltage from the red to black wire at the motor when it is acting up and you see that you have 120 volts your motor is the culprite. if you are getting voltage that means the timer is trying to turn the motor but it cant because there is something wrong with it.
    also have you checked your door switch. with the door open you should not have continuity with the door closed you should have continuity. check this also may be a suspicion
4 Suggested Answers
  • 5 Answers
SOURCE: Kenmore 80 series. No lint
lint trap is blocked.Take off back cover, clean it out. un-plug it.theres about 15 screws
Posted on Sep 04, 2010
Testimonial: "Dryer is now working. Thanks for your advice."
SOURCE: I dropped a screwdriver down the lint vent on the ...
I have done similar three different ways. I used Duct tape wrapped around the end of piece of garden hose shoved down the lint trap hole. Used a magnet instead of duct tape in similar fashion. Also used a pieace of large then garden hose with a shop vac, item becomes lodged on the end of the hose just long enoght to remove from slot. All three worked and resulted in a good handshakes from those in need.
Posted on Jul 01, 2010
canwoodjc
  • 3301 Answers
SOURCE: The dryer keeps shutting off saying lint filter
unplug the machine for 5 minutes that should reset it
Posted on Jul 04, 2011
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 800 6983 Electric Dryer
My Kenmore dryer keeps cutting off
Vacuum all of the air passages including the hose to the outside vent. Remove the lint filter and wash it in hot water and detergent; rinse and replace after drying. Restricted air flow may be tripping an over-temp switch.
Oct 12, 2009 | Dryers
My Kenmore 80 series dryer is shutting down
Please post the complete model number of the appliance.
Possible problems are -
1) Motor bearings are failing (lack of lubrication).
2) Idler roller is failing (lack of lubrication)
3) Blower bearings are failing (lack of lubrication)
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Dryers Logo
1,121 people viewed this question
Top Dryers Experts
Marvin
Marvin
