Hi, I have a 2004 Fleetwood Wilderness and I would like to use a window ac instead of the built in Coleman ac unit. I am wondering if there is a large rubber type seal I could place in one of the windows and slide the ac into the seal from outside. The ac unit would be on its own stand to handle its weight, but finding such a seal is my real problem.
  • 57 Answers
SOURCE: window or wall mount
The differance between a window and wall mounted A/C is the mounting system.
Window units are usually smaller BTU systems they set in the window, so you do not have to cut a hole in the wall to install it.
For a bedroom say 10 x 10 you can use @ 5000 btu it plugs into a standard 120 volt electric outlet. If the room is bigger then go bigger say @ 6000 btu or so. Take your room dementions with you when shopping for a unit. sometimes they have sizing on the side of the unit box.
Wall units are usually larger units. Like whole house 18,000 btu
they slide in and out of the case and use a 240 volt seperate circuit.
Best place to shop for A/C's are Home Depot, Lowes, Sams Club, B.J.'s, and Cosco they buy in large volumeusually give a Good deal I've seen 5000 btu units as low as $89.00
Just don't drop the unit out the window when installing it
From the second floor it will void your warranty. LOL
Good Luck Phil
Posted on May 20, 2008
motor1258
  • 6674 Answers
SOURCE: ROOF TOP AC UNIT ON COLEMAN POP-UP LEAKS
Does water drip out of unit on the roof while running ? If you look under the unit on the roof, you should see one or two little drains sticking down., that may be plugged up. Piece of wire or something and poke in the holes on the sides of those drains to make sure they're clear. Usually there is a plastic/nylon pan on roof unit to catch that moisture, and drain it off. Could be overflow because of the plugged drains, or I have seen the odd one crack but not too much recently, mostly back 5 yrs ago or so they had a run of them.
Posted on Aug 14, 2008
SOURCE: 7300 Series AC
3800 watts ran every thing just fine.
Posted on Sep 17, 2008
louislevel_2
  • 374 Answers
SOURCE: samsung ac model aw25ecb7
hi! bill,
water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
Posted on May 01, 2009
SOURCE: Window Air conditioner installation
I use sheets of styrofoam on the inside of the window. Cut it to fit the width and height you need to seal around the ac casing to inside window frame.
Posted on May 20, 2009
What kind of generator for a 1978 Wilderness trailer
1978 Wilderness Prices, Values and Specs Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
Mar 27, 2017 | Televison & Video
What refrigerant is in a Coleman 7300 Series AC Unit, on a 1995 Wilderness Camper?
This unit uses R-22. Here is a link to the service manual:
www.bryantrv.com/docs2/docs/rvp/rvp6789mech.pdf
Jul 17, 2015 | Coleman Heating & Cooling
Waterfilter on wilderness 270 rbs
Repost under RV's for the posiblity of an answer
Mar 13, 2014 | Fleetwood 2009 Wilderness 270RBS
Need to locate a owners manual for a 2004 fleetwood wilderness advantage2952bs fifth wheel
Contact the manufacturer and provide them the Model number. If it is still in print they can provide you a copy for a fee.
Apr 22, 2012 | Electronics - Others
I need the fuseblock location on a 2004 Fleetwood Wilderness 5th wheel RV
There are two fuse block. One for high voltage block. It's next to input wiring block. Another on for DC voltage. It's in PCB board.(o.5ml)
Oct 27, 2011 | Dometic Rooftop RV Air Conditioner
Need a schematic for Coleman 6759 mach 3
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Aug 20, 2009 | Coleman Mach III Air Conditioner
Why type of freon goes into a coleman AC, 1994 Fleetwood Country Villa?
After some searching it sems to use R-12 freon. It is getting a bit hard to come by and you have to be licensed to purchase it.
Jul 06, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
