Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My bf's Mac desktop and my PC laptop will not work at the same time after I set up a WEP or WPA-2 key on our DLINK WBR-1310 router. What do I need to do?
  • 27 Answers
I would have the router make a new key and then try that in both machines, if that does not help, then I would reset the router to factory and start over again.
Posted on Jun 21, 2009
I have lost my disk and need to program a password, due to nieghbours using my wireless. How do I do this
Hi evan,
Basically you don't need a CD if you want to change the password or put a password on the network all you need to do is to access the Wireless Settings Page of the Router and put or change the Network Key. To access your router you need a working computer connected to the router then open a Browser then type 192.168.0.1. the Username is admin and the password is blank. Go the the Wireless Settings Page and under Wireless Security Mode you can change the Security Mode to either WEP, WPA or WPA2 then input your desired password.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Feb 04, 2011 | D-Link 802.11g Wireless Router WBR-1310...
How can I get my WEP id again...I lost it?????
This Utility program from HP will help you locate few details on your network
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Regards,
Ron
Nov 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Can conect wireless ,ethernet cable work fine but not wireless
.Log into router ( 192.168.0.1) enter into the browser window.
2. Verify wireless router name( on the computer) >>> ( on/off) on the status page in the router.
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Here is the instruction set for your model router :to set it up wireless follow the emulator instruction at this link:
http://support.dlink.com/emulators/wbr1310_revA/104/wizard.htm
This is for all routers to set up wirelessly.
Aug 11, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How can i secure network
By going to the security setting in the router and assigning a WAP/WEP "Key" this will then enable security. Please consult your manual for how to do this.
ftp://ftp10.dlink.com/pdfs/products/WBR-1310/WBR-1310_ds.pdf
manual above
Aug 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a network set up with this router WBR-1310 version 1.1 . When my son came over with his laptop he could not get it to connect, and now I have been trying to connect another laptop that was not set...
The WPA or WEP encryption key is configured/enabled in the router's wireless settings. The router's SSID, WPA or WEP etc. needs to be configured in the laptop's wireless card settings fir the laptop's to communicate with the wireless router.
Please click on this link for information on how to secure your wireless network, configure the wireless router and configure the wireless card in the laptops and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 19, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have reason to believe someone is using my wireless connection to no good use. How do I make this " secure"?
Surf to the IP of your router, enter the management interface and switch on security. Use WPA or WPA2. Make sure you make a note of the password you set up, or you'll never connect to it again ;)
Oct 11, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Forgot D-Link 1310 wireless password - how do I retrieve it
What password? Are you referring to the WEP or WPA-PSK password? If yes, I would like to inform you that no one could give you the exact WEP or WPA key. Even if you check the utility of the router.
What you need to do is to reset the router to factory default and then reconfigure the router. That's the only way that you could do in order to set a new password.
Have a good evening!
Aug 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-link wbr-1310
First check to be sure the ip address of the router IS 192.168.0.1, do this by clicking Start/Run and in the Run window type CMD and hit the enter key, this will give you the MS/DOS command window, at the courser type ipconfig /all, then check the ip address shown for the gateway which is your router. If the ip is correct, put a cat 5 cable from the router to the computer and type http://192.168.0.1 if that is the correct ip address and if it does not give you the logon page for the router reset to router to factory defaults as per owners manual. if this works please rate the solution as a FixYa. Thanks BPCS
Jan 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
