Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
My evcon central ac (inside) fan won't work.when it first happened the unit got really hot I shut it of at the breaker and have since then been trying to get it working does not seem to be getting hot now and every thing else seems to be working but the fan. I can turn the the blade easily by hand it spins freely. do i need another fan or is there something i,m missing.
    President:
  • 3,433 Answers
The thermal limiting switch is not working It is supposed to preventheat. have it changed before the place burns down.
Posted on Jun 23, 2009
I was checking my central ac, heater. It clicks, gets hot, then does nothing. Blower doesn't kick on. If I turn it on the ac section, outside unit fan, and inside blower motor all work.
Check that the filters are clean, Common failure on most air cons. If they are blocked or dirty, the indoor unit gets really hot and keeps switching off as it thinks it has reached room temperature. WASH the filters in water. Dont vacuum or brush them.
Oct 03, 2015 | Heating & Cooling
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
I have a Goodman A/C unit model # GSC130361F A and a Evcon
The indoor fan should cycle with the outdoor part, make sure the thermostat is not set to fan "ON" and if the fan is on "AUTO" it could be a wiring issue or a fan relay that is stuck.
May 28, 2010 | Goodman CLQ36AR49 Air Conditioner
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Coleman evcon central unit outside fan wont come on is very hot
compressor shuts off when outside tempature drops.
Jun 05, 2008 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
141 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
