Question about Mach Speed VENOM V2DP Motherboard
HELP ME PLease!!!
Hi! I have a 1995 eclipse 2.0 DOHC non-turbo. I have a Venom 400 control module and i cant find any instructions on how to hook it up. Iv been looking for wiring diagrams but have had no luck! Can you please help me??
  • 208 Answers
Theres 2 types of engines. the non turbo is usually similar to a neon chrysler.. ( i have one) computer is under hood by the "bubble" not a real mitsubishi comptuer which is inside the car nto unde the hood.
ecu by fusebox=chirsler RS model if ecu inside car mitsubishi.
Posted on Nov 03, 2007
Left fan wont turn on my 1999 eclipse 2.4 non- turbo
Try to change the temp switch.could also be the control module
Nov 17, 2012 | 1999 Mitsubishi Eclipse
Where does the power steering belt go to on a 93 mitsubishi eclipse 2.0 16v non turbo
Hope this helps!!! Please don't forget to rate....thanks!
The power steering pump drive belt-1995-98 2.0L non-turbo engines
May 08, 2011 | Mitsubishi Eclipse Cars & Trucks
I need the diagram/schematic of the vacuum tube layout of 2.0L DOHC
Hello redeemer524,
Below is the diagram. I hope this helps.
Apr 14, 2011 | 1999 Mitsubishi Eclipse
Where are the timing marks on a 1996 Mitsubishi eclipse?
If you have the 4-Cylinder Non-Turbo, or 420a engine, here is the overhaul manual for it, including the complete timing instructions:
If you have the 4-Cylinder Turbo, or 4G63 engine, here is the manual for it, including timing instructions:
Mar 18, 2011 | 1996 Mitsubishi Eclipse
Firing order 95 eagle talon non turbo, diagram
1995 Eagle Talon AWD 2.0 liter DOHC VIN "Y" (also FWD 2.0 liter DOHC VIN "Y" )
Hope helps with this (remember rated this help) Good luck.
Jan 21, 2010 | 1995 Eagle Talon
1995 eagle talon with a axpi S-AFC 2 and g16 turbo 2.0l dohc
You need to switch your programming in your apexi safc2, your air to fuel is wrong. There's alot of places on the internet to look. Try typing in eclipse safc settings, check DSM sites there is alot out of them out there. I have had several 1g and 2g DSMs.
Nov 05, 2009 | 1995 Eagle Talon
I have a 96 mistubishi eclipse with 2.0 non turbo that has a code p1391 can anyone help me please?????????
Tests/Procedures: 1. Check the Crankshaft Position Sensor (CKP) and Camshaft Position Sensor (CMP) signals with a lab scope.
2. Check the wiring and connections at the CKP and CMP sensor. Potential Causes: Camshaft Position Sensor (CMP)
Powertrain Control Module (PCM)
Aug 08, 2009 | Mitsubishi Eclipse Cars & Trucks
P1789 and p0700
you can get all the required parts at either the local garage this will be second hand. you can get this at the mitsubishi service center or at
Jan 05, 2009 | 1995 Mitsubishi Eclipse
1998 Mitsubishi Eclipse 2.0 non-turbo DOHC engine vin y. Car stalled and turns over but will not start. Towed to repair shop and at first they said it was a defective cam or crank sensor, but now they say...
don't get the "Cardone ECC model 793013" . i just check it out and when you click on the " See all vehicles this product fits " link, it shows this:
5fcbf9f.jpg ------------------------------------------------------------------
the problem with it is that the '97 PCM will not work on a '98. the pinouts on them are slightly different. The only 2 years that are interchangable are the 98 and 99 year models.
The part number for the correct one is 5293190AC.
If you get a remanned PCM that needs progamming, anyone or any shop with the correct programming tool can do it.
1995~1999 Mitsubishi Eclipse RS & GS with 2.0L non-turbo engine (Chrysler 420A engine) ECUs have been equipped with reprogrammable processors since 1995.
To reprogram Mitsubishi vehicles, you must use one of two different reprogramming tools. For the 1995~1999 Mitsubishi Eclipse RS & GS (with Chrysler 420A engine), you must use a Chrysler Flash Reprogramming Unit, MIT992000-A . Click here to order one from SPX, or call them at 1-800-533-5338.
I would suggest just buying a used (98 or 99)PCM. Then all you have to do is unplug the old one, take out 3 bolts to remove the bracket/PCM, pull it out, 3more bolts to remove the ecu from the bracket and bolt the new one in place. Its about a 5 min. job.
Nov 29, 2008 | Mitsubishi Eclipse Cars & Trucks
Mach Speed VENOM V2DP Motherboard Logo
207 people viewed this question
Top Mach Speed Computers & Internet Experts
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
