Question about RCA Televison & Video
In the last little bit when trying to turn on our tv it would just click. After awhile it would come on, but now it will not come on at all.
  • 439 Answers
If this is an older tube style tv, the power supply for the gamma is bad or the tube itself is bad. If this is the case, the tv should be disposed of properly as it is done. It cost more to replace the tube or power supply in these tvs than it does to purchase a new one. I suggest looking on Craigslist in your local area if you are in a pinch for cash.
Posted on Jun 21, 2009
My 2000 Ford Expedition has been parked for awhile and will not start.
You need a good battery. It should read 12.6v while not running and 13.5v + while running. Sounds like a bad cell. Not curable.
Mar 30, 2017 | Ford Expedition Cars & Trucks
When you try to turn the tv on, all you get is a blinking red light, if you unplug for awhile, sometime it will come on.
Symptom: tv turns on, tv clicks once, red light comes on. Then, tv either works for a while, followed by a click, no video, normal sound and flashing red light; or, tv immediately clicks, no video, no sound, red light flashes. If that is the problem, you need to replace the convergence ICs. I had to do this twice. The two convergence ICs are mounted on palm-sized aluminum heat sinks. The heat sinks are soldered to the main circuit board. There are 4 pins soldered to the board for each heat sink, and 18 pins soldered to the board for each IC. Some of the heat sink pins are a bit difficult to desolder. The pins for the ICs are not difficult to desolder, but you must be careful not to overheat them. The heat sink and the IC come out as a unit, after all pins are desoldered. The IC is screwed to the heat sink. The correct replacement IC is a Sanyo STK392-110. I got mine from B&D Enterprises. They were not expensive. The new ICs need to be mounted to the heat sink with a heat transfer paste. I used Arctic Silver from my computer processor heat sink. Installation of the heat sink/IC assembly is a bit tricky, since you have to align all 18 IC pins and the 4 heat sink pins. When all the pins are visible through the holes in the circuit board, resolder everything. The TV should now work. Be sure to replace both ICs. My first repair was done by a technician, who obviously only replaced one. That repair only lasted a couple years, before the problem returned.
Mar 22, 2011 | Toshiba TZ55V61 55" Rear Projection...
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
TV turns off and on
you have bad electrolytic caps in the power supply---remove power supply replace swollen caps--if you do not think you can replace caps try shopjimmys.com enter model number scroll down to find power supply-if they do not have in stock write down part number then google it to find one
Sep 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Tv won't come on
sounds like your on/off switch just bit the dust happened to me had to get a new TV check with the store you bought it from they may be able to suggest something else, they may even be able to repair it
Aug 02, 2009 | Samsung LN46A650 46 in. LCD HDTV
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sony tv problem
You have a loose solder connection or two. If I knew the model number of the set, I could be more specific. I would expect the repair would run about a hundred dollars, so make sure the picture quality is great before going to the expense.
Aug 02, 2008 | Televison & Video
Sony KDP-51WS655
how many times does the light blink?
Feb 19, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
My tv will not turn on
do u hear any clicking sounds whn u press the button any relays make a clicking sound
Jan 10, 2008 | Zenith ZLD20A1 20.1 in. LCD Television
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
