Question about Dell Inspiron 1200 14.1 XGA LCD Display-320-4222 (3204222) CD-ROM Drive
Dell Inspiron 1100 Memory speed
Can i put on my Dell 1100 Inspiron a PC3200 memory?
the key of letter "D" "oes not function unless I touch it ..harder than all other keys.My Email ID
  • 233 Answers
Re: Dell Inspiron 1100 Memory speed
Vacuum out the keyboard when the computer is OFF.
Use a thin wide object such as a metal fingernail file to pry off the "D" button, there is probably some dirt under there, then vacuum.
You may have to disassemble the key board, and wash it out if the offending item is something like soda of OJ.
Be sure to draw a map of the wiring connections.
Not as scary as it sounds when done on a desktop computer.
Posted on Nov 21, 2007
0 characters
3 Points
How do I adjust brightness on my Dell Latitude D6...
Look for a key labeled "Fn" (blue lettering) on the lower left side of the keyboard
Hold the "Fn" key and then use the Up/Down arrows to adjust brightness.
If that doesn't work, reboot your laptop and get into the BIOS. There is a screen for brightness. I don't recall how it is labeled, but it's one of the last pages as you cycle through the BIOS options.
May 20, 2010 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
DELL Latitude D400 - what are the series of (blinking) icons?
sometimes this indicate a fault with memory or the system itsef.Before you begin you will have to remove the battery and the ac adapter.Remove the memory modules .Replace the battery and the ac adapter without the memory.Power it on if it comes on and beep several times then the memory is bad.If not remove the battery and the ac once again.Press and hold the power button for twenty seconds to clear the nonvol memory.Replace the memory the battery and the ac adapter.If still no go remove all the same items along with the hard drive and cd rom,Insert the battery and the ac adapter try again.If you hear a beep this time replace the battery(remember whenever you install to remove power).If nothing works and you none of the desired results you will have to replace the motherboard.
Good luck
Jul 16, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Dell Inspiron 1150 - Wont boot & nothing on screen ??
The fans on this unit are thermostatically controlled and only turn on when the predefined processor temperature is reached, so upon turning the unit on It will spin up too full speed and then seem to shut down until it is needed.
If you are getting no beep tones and since you have already tested your memory, I am forced to assume that either your processor has retired or your cmos is wrong, Since you sound like you have already opened the unit then locate the clear cmos jumper/switch on the board and clear your cmos which will reset to defaults.....if you still have the same problem then I reccomend trying a different processor.
Ed Meyer
May 24, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Need to transfer files on itunes to memory stick
Go to My documents, My Music, itunes, itunes music, select all the files/folders you want, by holding down the CTRL key and left click on all of the folders that you want to put on your memory stick and then right click and select copy. Go to My Computer and double click on your memory stick, then right click and select paste.
Jan 15, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Where i can find dell ----1100 inspiron ac adapter???
these are in plentiful supply on ebay.
or just look on
Apr 26, 2008 | Dell Inspiron/Latitude C-Series AC Adapter...
Dell Inspiron 1200 no POST
There are two memory slots on this model, but there is no "Onboard" memory. Without the memory that you removed, your laptop will not post. It sounds like a dead motherboard issue to me, especially since you have pretty much torn it down to barebones. Rarely, this can also be caused by the processor but it is less likely. Unfortunately, since you cannot keep it running, there isn't much chance of diagnostics. I hope this helped.
Apr 20, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Latitude d600
try swapping with a known good HDD, if still same thing happens then your motherboard is shot. Replace motherboard.
Feb 12, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell cpx
check your keyboard connector & key board.check the control key, properly it could be happen if it get connected always.
Jan 28, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Inspiron 1200 laptop
Sounds like you have a bad Stick of ram.If you have 2 sticks remove one then try to load the operating system.If that doesnt work replace it with the other one and try to boot.If you are not sure what ram is leave a comment and I will explain.If neither work buy a new stick of ram and that should take care of your problem.Rate me if this works!GOOD LUCK!
Nov 17, 2007 | Dell Inspiron 1200 14.1 XGA LCD...
CD Drives Logo
61 people viewed this question
Top Dell CD Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
NewYork kyocera HP...
Are you a Dell CD Drive Expert? Answer questions, earn points and help others
