Question about Garmin iQue 3600 GPS Receiver
Kicking on and off
When lid is up ique shuts on and off when lid is down can navigate within ique
  • Anonymous Nov 11, 2007
    I disabled the WAAS as described and the unit appears to be normal again.
    Thanks very much!!!!
  • Anonymous Nov 16, 2007
    With the antennae up and searching for satellites, once the third satellite was locked in, the Garmin would turn off and back on repeatedly. I downloaded the program again, did hard reset and the problem remained.
    Then I found this website and disabled the WAAS as described. Now the unit returned back to normal operation. Thanks!!
I think you're talking about a gps problem that I experienced also. Go into gps preferences and disable waas and it will function normally. I found this solution on another site and it helped me.
Posted on Nov 08, 2007
  • 752 Answers
By lid, do you mean the leather cover?
Kenmore 110 washing machine thermally cycles
Does it operate properly if you or something holds the switch down? If yes, then extend the end of the lid switch with hot glue, epoxy, or silicon glue to allow the switch to be pressed sown further. You can also build up the contact area under the lid if you choose--same result.
Aug 07, 2009 | Washing Machines
Garmin iQue M5, Not aquiring satellites
Two possibilities - Antenna (in power cable) or electronics related to antenna. First, do a hard reset. Place the pen top into the RESET hole for 3 seconds...
Next, when the unit is powered, page over to the screen showing satellite signal strength....
If NONE appear within 1 minute (and you are outside and NOT under trees), you have an antenna or antenna interface issue.
Garmin WILL repair the unit for 3 to 4 times its value... A 265WT GPS is cheaper, faster and more accurate. The IQUE is no longer worth repairing....
Apr 07, 2009 | Garmin iQue M5 GPS Receiver
Won't turn off or on, wont do anything, is lit up though
Might try a warm reset. Unscrew the plastic top of the stylis. and push it into the reset hole in the back of the unit, remone it from the reset hole, then turn unit back on.
Mar 15, 2009 | Garmin iQue 3600 GPS Receiver
IQue3600 maps unavailable
You can get City Navigator 2008 CD from your local Garmin dealer. Cost around $100.
It updates via MapSource program and USB connection to IQue 3600.
Do not get "NT" maps as 3600 does not understand "NT" compression
Sep 23, 2008 | Garmin iQue 3600 GPS Receiver
Active Sync USB OK but City Navigator won't find device.
Somewhere I read that if you do a soft reboot to the iQue M5 it will connect to the City Navigator. I did this and it seemed to work, although between downloading and uploading I had to do it again. The process of loading map set (entire US) took an extremely long time (about 3 hours). Also, if you try to receive maps, waypoints and tracks from device all at once, it chokes.
Jul 20, 2008 | Garmin iQue M5 GPS Receiver
Garmin ique m5
eBay should have some, though they may be used.
May 24, 2008 | Garmin iQue M5 GPS Receiver
IQue 3600 missing disks
The simplest method is to update the software for the Mapping/Data, the one you probably had is sooo out of date!
City Navigator North America 2008 DVD
MapSource City Navigator North America
(includes access to the whole disk)
Garmin Part Number: 010-10474-00
U.S. List Price: $139.27 (for domestic US market only)
Sep 26, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
29 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
