The 12-volt TV for my motorhome won't power on. It's a FlexVision Model AVT-988, 9' color DC operation, distributed by Audiovox. * I found a bad 15amp fuse for the TV circuit and replaced it (probably shorted when careless with a multimeter when checking a nearby 12-volt accessory outlet), but still no luck. * It's definitely getting power to the DC input, as checked with a multi-meter. * It's not the TV fuse nor the fuse holder, which in the past had popped loose from the circuit board. I need the TV fixed rather than replaced with another type because it fits perfectly in a molded plastic cover - any other TV would look very odd to renters that rent our RV.
techman
  • 3130 Answers
SOURCE: Hitachi 60FX20B
If you hear the unit comming on and theres no sound or Picture, then theres a fault in the horizontal sweep/HI Voltage circuit. This should not be fooled with unless you know the safty issues with HI voltage as theres voltage in these sets even after they are unplgged for a while. Good Luck
Posted on Jul 06, 2006
SOURCE: Sony KP61V90 Goes Black and White
this may not help but, my sattelite tunner produces this problem sometimes, it goes black and white picture. it will work its self out. useually it does not take that long, if that is the problem..
Posted on Jun 03, 2007
SOURCE: Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Posted on Mar 27, 2008
  • 927 Answers
SOURCE: C4075 burnout.
Good day, javiquez;
The cap C407S that you burnt in the TV is in the circuit that feeds the G-2 to the CRT's. So, it makes sense that your picture quality has suffered. Here is the information on the failed cap and other part I would recommend changeing:
1. C407S; part number 2201-000406; description; c-ceramic,disc; 270 pf, 10%, y5p, 2 kv (2000 volts).
2. D402; part number 0402-00586; description; APIH, 2 kv, 1 a (amp).
Hope this was helpful, good luck, big IRISH.
Posted on Jul 19, 2008
j_del
  • 1586 Answers
SOURCE: 12 Volt Cigarette Lighter / Accessory dead
Most likely just replace it. You could pull the fuse and then use a small screwdriver to try and pull the tabs inside the receiver in toward the center a little. It could be that repeated insertion and extraction of the lighter or accessory plug has bent them outward enough that they're not making sufficient contact to power what you plug in. If that doesn't work, replace it and then put the fuse back in.
Posted on Jul 21, 2008
Where to look for flyback tranformer on audiovox avt-988
It can be bought from most of the electronic spare part selling shops.
Aug 18, 2015 | Audiovox Televison & Video
Schematic Diagram for Audiovox AVT-1475
Send your email address to me by Fixya, and get back a copy of the schematic you need by return mail.
Oct 30, 2012 | Audiovox AVT-1475 13" TV
Where can buy a dc power cord for an audiovox model avt-1475?
Tries websites like Amazon.com,Ebay.com,Partstore.com to buy a new a/c power cord.
May 12, 2011 | Audiovox AVT-1475 13" TV
Where does the 12 volt dc power for the roof a/c come from
comes from your 12 volt battery that is installed in your RV/ Motorhome, which also runs some of your lights in the RV/Motorhome too.
Jun 19, 2010 | Dometic Rooftop RV Air Conditioner
Audiovox 12 volt avt-1475 tv problem
success!
this is the flyback for the 9 - 13 in craig / audiovox tv and at about the middle of the page is where it is for sale ,mc- fbc-015, 43-74-1402
http://www.technotronic-dimensions.com/Products2a_z.html
Mar 02, 2009 | Audiovox AVT-1475 13" TV
I DON'T GET A AC POWER CORD JUST THE DC FOR MY VAN.
I'm looking for that TV For my van..we had same tv and now it doesn't work. How much would you sell it for?
Thank you
Mar 30, 2008 | Audiovox AVT1498 TV
YOu can buy a power cable at your local Radio Shack store....
Dec 17, 2007 | Audiovox AVT-1475 13" TV
12 DC ADAPTER
Try looking for a Jensen JE2043 with identical specs for the adapter: Input :100-240VAC (50-60Hz); Output : 12Vdc 6Amp. You can try ebay .
Alternately a 13.8/6A regulated power supply for communications equipment would also work. You simply need to hardwire the crown plug and red/black wires.
Good luck and kind regards.
Nov 05, 2007 | Audiovox JE2043 20 in. EDTV-Ready LCD...
No Color on my Audiovox AVT-1498
That model has a history of bad solder connections in various circuits. I would not be surprised if that is the case with the color circuitry. You may get the color to come and go by slapping the sides of the TV or lifting one corner about 1/2 inch and dropping it. If it does, it is a bad connection and possibly fixable. If no change is noted, it could be a bad semiconductor or capacitor, etc., causing the symptoms. For that size set, it would probably be cheaper to replace with a different brand. Toshiba has a nice 14" model IMO.
Feb 11, 2007 | Audiovox AVT1498 TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
