Question about Rainbow Rainmate Air Purifier
How much water to put in rainbow rainbow and should it blow out air
  • 11 Answers
Fill the water in the basin to the top of the peg in the middle of the basin. (a little over an inch in the 2 quart basin) The Rainbow blows out air just like any other vacuum cleaner does throught the exhaust port. It will blow out there while the vacuum is running if the exhaust port cover is missing. Otherwise, with cover in place, it will blow out air all around the mid section of the canister while it is running.
Posted on Jul 03, 2009
Is the rainbow rainmate like a essential oil diffuser?
If the instructions don't say so, I would not do it. Oils can clog air purifiers that are designed for such pruposes.
Jan 17, 2015 | Rainbow Air Purifiers
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
How much water to put in the globe
one inch above the line about an inch off the bottom of the globe.
Jun 13, 2009 | Rainbow Rainmate Air Purifier
Rainbow rainmate broken.
You can do one of two things: order a new spin wheel from ainbow, or you can go to Lowe's or home Depot and get a product called GOOP. Get Marine Goop if the store has it. Put toe Goop on the edges of the broken parts and let it set a minute and then put the two broken pieces together. Spread a thin layer of GOOP over the crack onto both broken parts and let is set about ten minutes or so while you hold them. set the part down in a way that doesn't throw the parts off kilter and let them dry overnight. Problem should be fixed.
Mar 18, 2009 | Rainbow Rainmate Air Purifier
Rainbow Rainmate making a screeching noise!
just take it to ur local dealer they will replace it or fix it.
Feb 12, 2009 | Rainbow Rainmate Air Purifier
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Rainmate question
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful not to place the machine too close to the edge of whatever it's on as it may fall off. The rainmate can be ran 24/7 (mine does :D)as a side note the only upkeep it should need (other than the water of course) is check the little hole on the bottem of the spinner. if that is ever clogged just punch it though with a toothpick.
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Air Purifiers Logo
1,081 people viewed this question
Top Rainbow Air Purifiers Experts
misskolika
Level 1 Expert
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
