Question about Verizon Communications enV2 Cellular Phone
Envy 2 phone wont ring or vibrate - Verizon Communications enV2 Cellular Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
Phone wont ring
there are 2 speakers, 1 for ring tone, 1 for music, ring tone speaker is fragile easily broken if phone is dropped, have to replace the 2 as 1 unit
Sep 18, 2009 | Sony Ericsson W890i Cellular Phone
HTC Touch Pro Won't Vibrate
So you having problem with vibrate capability?
Try this:
1. Make sure your phone not in charging (it won't vibrate for several phone like e.g. NOKIA)
2. Have you dropped it? If yes, immediately contact the customer service.
Hope this will help! PM me if there's any questions =]
Jul 07, 2009 | HTC Touch Pro Smartphone
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
May 29, 2009 | LG Shine KE970 Cellular Phone
Pantech c3oo wont ring
It is in vibrate mode...it drove me crazy too!
Simply press and hold the "*" key at the lower left to exit vibrate mode.
Apr 07, 2009 | Pantech C300 Cellular Phone
Lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Jan 12, 2009 | LG Shine CU720 Cellular Phone
Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
Dec 12, 2008 | LG VX8300 Cellular Phone
Ringer
go into profile and set ur message setting 2 silent and ur ringing tone 2 set anytone./.it wont make noise. reply me
Jun 05, 2008 | Samsung C417 Cellular Phone
Vibration wont work
All I did was wait for it to come back. I think it might have had something to do with the battery being low. However, that's never happened to me when the battery was low. When I plugged my charger in, I got a text message. I had the ring on high and vibrate. It vibrated for a second, then it just continued to ring. Once my phone was fully charged, the vibration came back. I think it was just a glitch in the phone. Razr's suck.
Mar 02, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
269 people viewed this question
Top Verizon Communications Cell Phones Experts
ismael castillo
Laxman Bisht
Laxman Bisht
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
