Mitsubishi WS-55805 55 in. Rear Projection Television
Problem for Mitsubishi WS-55805 55 in. Rear Projection Television
SAME TV(mitsubishi HD1080 series)-- corners of screen are bent
By sunsetfar922 on Jun 21, 2009
I converged the colors...the center of screen is great..But the corners are still off.. top corners are pulling image up and bottom corners are pulling it down. Can i adjust this through menu?...Inside TV?
Comments:
Jun 21, 2009
- thanks...I did adjust the red and blue...there wasnt a green...And that is the only color now that is bending. Is there a way to adjust that color? I'll try the repair myself.. Im semi handy...and have plenty of patience...thanks again..that was quick!!
Best Solution
posted on Jun 21, 2009
Helpful)
Ecollier2012
Rank: Guru
Rating: 93%, 558 votes
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi WS-55805 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55805 55 in.
Do you recommend Mitsubishi WS-55805 55 in. Rear Projection Television?
Answer
Answer
Green light does not come on at all, tv "clicks" a couple of times but does not come on...
Answer
The picture has a rounded effect with the three colors not lining up on perimeter.
Answer
Need to purchase the HD1080 receiver to work in conjunction with my W55805, 2000 Platinum series... (More)
Answer
I have a 2000 WS 55805 and the red seems to have disappeared from the picture. Do I just need to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
