Question about Kenmore Washing Machines
Weak agitator burning smell
Very weak agitator  then washer stops and has slight burning smell. It is a Kenmore/ Whirlpool top loader.
  • Anonymous Mar 22, 2014
    agitator stopped working
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
My Beko washing machine has a smell of melted rubber and I found black bits on the drum. None of the clothes have been damaged but they do smell a bit. Is it overheating or something?
hi Alyson.
this is what i found on the internet.
WHAT'S CAUSING A BURNING SMELL IN YOUR WASHING MACHINE? If you notice a burning smell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The Burning Belt Smell Many top loaders are direct drive. This means they do not use a belt. The motor is directly connected to the transmission.
In Whirlpool and Kenmore models there is a rubber coupler between the motor and transmission that takes much abuse. It's very common for the fingers or the rubber itself on the coupler to break. A clicking noise with no spin or agitation along with a slight rubber smell are symptoms of this problem.?DIY repair is possible. Older models may also have belts that can be tighted or replaced
The new Whirlpool or Maytag washer can often be fixed without calling for repair.
To work on a top load HE washer pull the empty unit away from the wall. Drape a small rug or towel over the control to minimize damage to the wall and the panel. Lean the unit against the wall and the bottom will be clearly visible. Lie on the floor and note if there are rubber pieces or shavings under the washer. The belt may be rubbing against a plastic guard attached to the motor. The solution is actually quite simple: If the belt is shredded or worn you need to replace it. You can call a repair person or, if your washer is under warranty, the manufacturer. Or, if you or someone you know is handy, you can do it yourself!
Electrical Problems If your washer smells. The first thing to do if you notice an electrical smell in your washing machine and not a rubber burning smell, is to unplug the machine and call the manufacturer or a repair person.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
or go to this link might help you to find out more.
washing machine has smell of melted rubber and found black bits on the...
Nov 29, 2017 | Beko Washing Machines
I have a kenmore 700 series top-loader washing machine. Its about 8 years old but looks pretty new. My knob turns fine but the housing enclosure for the number does not turn with the knob. I have to...
The burnt plastic smell is probably the belt that drives the agitator. There may be something stuck (wrapped) around the shaft under the agitator that tightens the gears so the belt just slips and heats up. Remove the agitator and make sure the shaft is clear. also if it is belt and gear driven, check the gears. This means removing a panel or turning the unit sideways to inspect from below. The hum is the motor either not turning or turning with the belt too tight.
Hope this helps...
Oct 31, 2013 | Kenmore 24032\24036 Top Load Washer
My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
Oct 05, 2009 | GE WHRE5260E Top Load Washer
Agitating, ticking noise and then burning rubber smell
HI, the motor is failing slowly and, i recommend replacing this damaged motor asap before it starts to over heat and present a fire hazard.
Jun 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Agitator wont work, quiet hum and smell
Noises
Often something works it's way into the pump and makes a clicking or scraping noise. Another bad spot on this washer is the snubber ring that sits between the base and the drive unit.
1) Whirlpool, Inglis, (some) Kenmore washer..... Remove the agitator cap, some caps unscrew and some will just pull off. Look for a bolt and remove the bolt, lift up on the agitator...picture1picture2.
(2) Whirlpool, Inglis, (some) Kenmore washer.....Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
Apr 03, 2009 | Kenmore Washing Machines
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
54 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
