Question about HP PSC 2175 All-In-One InkJet Printer
I printed some copies on this and there were ink stains on them.Can you tell me what to do please? Thank you ahead of time for your answer. Hp2175 all in one
    Problem Solver:
I had not used the printer in a very long time .After use now ,problem solved .Thank you
Posted on Jun 21, 2009
I turn the printer on and it comes up with ink access door open however it is all closed
Thank you for using FixYa
The answer depends on the model. For more than one HP model I found that you can press hold the "#" and "6" as you power up the printer.
For the HP2175 follor this link to bypass the access door--
http://www.ehow.com/how_6747415_close-access-door-hp-2175.html
I hope this was useful and please comment if this was helpful to you.
Mar 23, 2011 | HP Office Equipment & Supplies
My hp2175 scans but will print anymore
Try to work through the possible solutions offered in this link., such as here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 15, 2009 | HP Officejet 5610 All-In-One InkJet...
Can I use the black cartridge only in my Hp2175?
You have to have both cartridges in for the printer to work.
To print in black only go to control panel, printers,properties,printing preferences,color then select gray scale.
Mark
Apr 10, 2009 | HP PSC 2175 All-In-One InkJet Printer
How come Alignment of Cartridge needs at each printing?
I just go ahead to print and do with what the printer wants me to do. Because I just bought 2 black cartridges, when I use them up, I will buy another printer, different brand, I regretted that I bought Lexmark printer, the ink tube is so little and very expensive. I wish I still had the previous printer . It was still good and new, it has bigger ink tube (1 1/2 times) but the only reason I turned it down, because it was only for printing & copy, it does not have scan or fax which I very seldon use those. Thank you anyway.
Feb 05, 2009 | Lexmark X8350 All-In-One InkJet Printer
Incoming faxes
I just want to know also if you have a problem in printing, scanning or copying. If so, it might be an issue with ink cartridges. However i would like you to follow these steps. Just click the word "SOLUTION" below.
CLICK HERE==>> SOLUTION
Please, let me know if the issue is still not resolve, so that i can go ahead and give you another possible solution for that.
Thank you so much.
adonscott
Jul 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Hp psc 2175 all in one SCANNER PROBLEM
This is only a software issue. Reinstall the software or try installing on other system
Mar 19, 2008 | HP PSC 2175 All-In-One InkJet Printer
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
Waste ink absorber
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
However, since I am skilled in the art of "frugal" you can also do things this way. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
Bada boom! like brand spankin new!
Oct 23, 2007 | Canon PIXMA MP130 All-In-One InkJet...
HP PSC 2175 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
