Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd 62526 picture freezes. turn it off and on again and it works for a few hours and it happens again. also can change input source and it un freezes.
Used reset on front and reset with remote. so far so good.
Posted on Jun 21, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
Hi I have the mitsubishi WD 62525 and I have replace all the bulgy capacitor, now the tv is working, but after a few minutes the picture start distorsionated to the point that is scramble. I turned off...
You have a multitude of surface mounted capacitors that have to be changed on the DVM module which is part of the Light Engine Assembly. Mitsubishi's are notorious for this problem. Mits charges $300.00 to refurb the Light Engine Assembly , which is not a bad price.
Dec 27, 2010 | Mitsubishi WD-62526 Projection TV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
I need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Dec 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
