Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Rheem Tankless water heater drain valve constantly leaks water. I've had the heater roughly 5 months and this just started a couple of weeks ago. It started leaking slowly at first but now it is a full flow in the small drain valve.
  • 6 more comments
  • Gary Morrow Jun 21, 2009
    I have the plastic tubing that came with it installed on the unit and running outside the house. It just constantly blows water out of it. Luckily it is going out the house and not inside; however, I'm sure it's not suppose to constantly leak. Is this the part you are referring to?
    This is the unit I have:
    http://www.rheemtankless.com/content/res...
    On page 18 it shows the relief valve of which I speak and the tubing is connected exactly like in the diagram. Everything is.
    I am sure the installation was done correctly and no parts are missing because as I stated the unit worked fine for 5+ months. This is a new development and has not always occured. If the unit were not properly installed or parts missing then it would have done this since the beginning and it has not...
    I replaced the pressure relief valve and I am still experiencing the same issue. As soon as I turn the water supply on it starts draining out the Drain valve? It's not suppose to drain out the drain valve all the time!
    I agree with your assessment, and I've checked the small little Drain valve. I'm just not sure if that whole part is faulty or what?
    There is a small rubber gasket and it is still perfectly sound with no wear or tear apparent.
    Can you tell me where you purchased the new part? I'll give you 4 huge hands if you do!!!!
    I'll head to Home Depot tomorrow and hope from there.
  • 3,866 Answers
I have the same issue and replaced the whole part because there are two gaskets one inside and one outside and this worked great would advise you do the same you be glad you did,
please do not shoot the messenger here :)
just replace the whole valve as if you just doing one gasket then the other gasket does not got long to go either.
Thanks
Reulds2008
Thanks for using fixya!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 21, 2009
  • 2 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Jun 21, 2009
    Sure there are a couple places like home depo sales universla parts for all of them also rheem themselfs would sale them you can even try ebay if you want it to come on your mail. Pretty much you major hard ware store will be your best bet! if the do not they will tell you who does as well. I bought mine from home depo it was a unversal kit.
    Good luck to you I know how much of a hassle you been though many tech with not real ansers I jhope this does help you :)
    I am willing to shak all four hands one at a time :)
  • Grand Canyon Tech
    here you go
    http://www.rheem.com/products/tankless_w...
    they would have them!! and they can ship them to you and it will be your best bet!!
  • Grand Canyon Tech
    if you do accept that soltuon can you please shhot me a rating to bring this to a resolve also I sent you a URL that has the part as well just incase you do not want a universal solution!
    Thnaks for using fixya.com
    Big four hands!
    Rulds2008
  • Grand Canyon Tech
    Grand Canyon Tech Jun 22, 2009
    This is my only way to contact you, I was wondering if this helped or not did you go to the link I gave you, If you find this solution helped and you rate and close it?
    Thanks For using Fixya.com
    Sergeant:
    Champion:
  • 255 Answers
I'm not a plumber, but valves have rubber gasket in order for water not to leak or float to control the flow of water.as long as no cracks or anything like that on the tubes/valves that may be the cause.because like you said earlier it working well when it was installed.
  • 3,600 Answers
Replace the pressure relief vavle it is defective. and do it right away it cost's $8.00 and should be under warrenty.
    President:
  • 632 Answers
Disassemble valve and ensure proper installation...your installation looks like the one in the diagram but you are not sure if no part is missed or placed properly...make sure rubber stoppers and fitted properly..
  • 332 Answers
The condensate line is not hooked up,,, you will see on the side of the vent a little rubber cap, take it off and contect a line to it and let it drain, also you should have no mre then 65lbs of pressure going into the unit to much pressure will make it blow off
Overflow valve on tankless Rheem was leaking & replaced with valve that has sensor from home depot. It is still leaking. Is there a specific overflow valve that I need to use on my tankless system?
The valves are the same specs. Is it possible that a new valve leaks, yew. However if both valve leak then there are other problems. Does the valve only leak when hot water is called for? Then check temperature setting on heater. Does it lek all the time? The water pressure is to high ,
  • Maximum Temperature Setting (Deg. F): 210
  • Maximum Pressure Setting (psi): 150
Why the relief valve at the water heater is leaking and what to do about it
Does tankless water heater require pressure relief valve
Jun 25, 2018 | Rheem Water Heaters
My Jacuzzi J-N180F tankless water heater will not even light.
Access your product manual.
I cannot find a product manual.
Some major company, like Rheem, makes this computer that heats water.
Call service technician to repair the unit.
Copy following link for overview of type of problems found with tankless computers.
For example tankless computers require continual maintenance on yearly and monthly basis to prolong expected life of product.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is older than 5 years, then assume it is like your 5-year old laptop computer.
Save problems, and repair the unit yourself, same day, by installing tank-type water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 27, 2013 | Jacuzzi 7.5 GPM 180000 BTU Internal Gas...
Error code C7 13
Before calling service technician, open following links for troubleshoot resources including Rheem chat, and Rheem contact, and possible product manual:
C7 13 might be bad flow control valve.
While the tankless is down, I suggest also catching up on general maintenance such as cleaning the combustion chamber and burner parts, checking vent drain line, and cleaning water filter, and de-liming the heat exchanger.
Some resources are shown following pdf:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Sep 23, 2011 | Rheem Paloma Tankless Water Heaters...
Installed a tankless gas hot water heater a few months ago, and ever since then when ever I turn on the hotwater, I get pockets of air coming out of the faucet. There are no leaks in the water lines, but...
1) Never, ever install tankless water heater, unless your wallet is 2" thick and you enjoy nuisance problems and recommended continual maintenance.
2) Add in-line air vent.
http://waterheatertimer.org/images/Air-vent-added-to-return-22.jpg
3) Look for check valve along the line. Look for mixing valve, pressure regulating valve, etc.
4) If you have recirculation system, remove cross-over check valve and see if problem is located there.
5) Contact Rheem. 800-432-8373 They will want model number, serial number, and name of installer. And might recommend contacting installer or plumber.
6) Increase water flow. Check water flow requirement of tankless (.5 gallons per minute activation) with actual flow at faucet.
7) Clean water filter at tankless unit.
8) Crossover at single-handled faucet.
http://waterheatertimer.org/Crossover.html
9) Fix all leaking faucets indoor and outdoor so no air is being sucked in.
10) Bad TP valve on water heater sucking in air each time water pressure pulls on the valve?
Additional resources: No information about air-in-line
Sep 20, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
I am geting a P1 error code
P1 error code is not enough water flow to operate the unit: increase water flow to unit.
http://waterheatertimer.org/pdf/Rheem-Error-code-P1.pdf
Error codes are considered start-point for troubleshooting.
Page 18 of maintenance manual shows how to clean water filter monthly.
Other causes can include faulty sensor, clogged in-line filter, clogged water softener, sediment in pipe, sediment at elbow, bad check valve, water leak, etc.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Rheem Tankless Hot Water Heater...
Our Richmond Tankless is showing a reading of a C2 error code. How do we fix this. Why is it doing this?
Before calling service technician, open following link for Richmond/Rheem troubleshoot resources including Rheem chat.
Error codes are considered start place for troubleshooting.
C2 11 is 'No ignition' or 'Gas is inadequate' or 'Ignition failure'
Error C implies ignition rod
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Jun 18, 2011 | Rheem Tankless Hot Water Heater...
No hot water. Constant beeping at the tank. Tempature gauge flashing 11.
Before calling service technician, open following links for Rheem troubleshoot resources including Rheem chat and typical service manual and typical product manual.
Error codes are start place for troubleshooting:
Error 11 is 'gas is inadequate' or 'ignition failure'
Open gas valve so handle is parallel with gas line.
Bleed air from gas lines.
Check that appliance is grounded.
Check igniter wires and harness for damage.
Check that vertical vent length does not exceed limit.
Other causes: Gas inlet solenoid valve, bad igniter, solenoid valve, flame rod.
Jun 14, 2011 | Rheem Tankless Hot Water Heater...
PTG-74PVP-2; Where can I see/get/download a parts diagram? I continue to have O-ring failure on what appears to be the Water Flow Solenoid. The unit is installed at my vacation home, I shut down and...
Open following link for troubleshooting resources including Rheem contact information.
High water pressure might be causing problem.
Use Brady BTG-100 pressure gauge to check pressure on nearby spigot.
Add a pressure reducing valve on incoming water line.
http://waterheatertimer.org/images/Check-water-pressure-250.jpg
Water heaters, tankless and tank-type are damaged by high water pressure 80 psi.
House plumbing fixtures also have shortened lifespan.
However if water pressure or water flow are too low, then burner will not activate.
Tankless are like bowling on a ship sometimes.
Repair most tankless water heater problems yourself, same day, any brand, for $320
May 02, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
My rheem was flashing IL . I flushed with 2 gallons of vinegar for 45 minutes. however when I restarted it still is flashing IL. Does something in the remote need to be reset?
Before calling service technician, open following link for Rheem tankless troubleshoot resources, including on-line chat
Rheem technical service bulletin for de-liming:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
De-liming Manual says:
10. Turn on the water shutoff valves, run a hot water tap to
purge any air from the water lines and check the system
for any leaks.
11. Turn on gas, electricity, and remote control thermostat
and set the desired temperature.
12. Run hot water from several locations to check the operation
and performance of the water heater.
If you have difficulties please contact the Technical Service
Department at 1-800-432-8373 or your local service agent.
Apr 18, 2011 | Rheem Tankless Water Heater Main Remote...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
143 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
