Question about Garden
4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
Have a 4.5hp Sears Tecumseh push lawnmower.
Prime 5+ times (primer not firm), start, runs 5 - 10 seconds and dies, harder to restart, have to put fuel in cyl head or carb cleaner in carb.
Rebuilt carb (5 times) , ultrasonic cleanse, all orifices open, new needle, seat, gaskets, air filter, no acid bath, did not remove welch plugs???, good float and adjustment, good spark and compression, cleaned gas tank and line, fresh gas 89 octane, oil change. Starts like a Banshee then dies in 5 - 10 seconds.
Ready to crush with my excavator - Good YouTube video!. Sears/Tecumseh will appreciate the advertising.
Free advice only please.
Desperate!
  • 2 more comments
  • reinis1 Jun 21, 2009
    Brass
    Will use the 11/32 bit to adjust. thanks,
    I think I have a plastic jet, how do I remove it? Saw a post on pushing down from the throat with a flat blade, afraid to break it?
    No holes in the primer bulb, but I have found they become lax, with time. Black rubber relatively soft. Not like the red firm ones.
    Not much resistance when pumped. Perhaps I need to let some time lapse between pumps?
    Thanks,
  • Anonymous Mar 16, 2014
    John Deere SB14 walk behind (10+ yrs old). Pull starter and engine turns over then dies. Wait 30 seconds same result, it will turn over then dies. Gets spark, fresh gas and fuel line appears patent. Pulled carberator and looks clean. Not sure where to go for here.
  • Anonymous Mar 30, 2014
    carb leks gas from primer vent
  • 284 Answers
Metal or plasic float?
Posted on Jun 21, 2009
  • 1 more comment
  • panilling9
    panilling9 Jun 21, 2009
    your adjustment on this float is not level like briggs
    if you havent done you need to take a 11/32 drill bit or adjust your float higher than level
    and the bit goes between the float and the casting of the carb.as a gauge for the setting
    you MAY HAVE a plastic nozzle they call it going up thru the center of the carb. with o-rings top and bottom of it
    that will have to be pulled and cleaned and 0-rings replaced
    does the primer bulb have a hole or no hole in the center of it?
  • panilling9
    adjust with the bowl gasket removed( the float)
    yes on the priming delay so it can do what it is supposed to do
    some are stubborn but they will come out (the nozzle) push and pull small needle nose to pull
    if you break it i think it is sold seperately from the carb. kit anyway.
    try rubbing alcohol also as it should or may help removal and reinstall especially with the new 0-rings
    be sure all orifices you see are clean some are small as a stick pin so you can use a stick pin to clean or smaller.
    the piece you screw in the carb. bowl to secure the bowl to the carb. be sure if it has orifices clean them good also
  • panilling9
    also be sure you float is empty
    shake it and you should hear NO noise from it
    sometimes fuel gets into it and makes it heavy
    replace if you hear something
    New Friend:
  • 38 Answers
Remove the bowl nut and in the middle of the nut get a sewing needle push through jet hole then u see two holes on side of nut make sure u see that needle in them
Posted on Oct 13, 2013
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
My lawn mower tries to start but then dies shortly thereafter.
Probably. Does it start after you push the primer and then die? If so, yes, it's the carb. For any more info, I'd have to have the model and type #'s off the engine. Dwain
May 17, 2009 | Craftsman Garden
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Garden Logo
1,937 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
