Question about E-Machines T6528 PC Desktop
E Machine T6528
I have ordered a new ATI video card and 1 GB DDR RAM for my pc. I have never been in a computer before. What do I need to know to install these items myself.
  • 2 more comments
  • longpipeplum Jun 21, 2009
    I went to the E Machine web site and looked up the upgrades for my T6528. I ordered the parts they offered to upgrade this computer.
    All the parts will be here in about a day or so. I will let yall know how it works. Thanks for the info.
  • longpipeplum Jun 26, 2009
    Worked great. Parts were installed in less than 10min. Thanks for all the info.
  • Joe Gornatti
    Joe Gornatti May 11, 2010
    First of all did you order the right video card and memory? You need to get 400MHz (PC3200) Expandable to 4GB Memory and a PCI Express (PCIe x16) video card.
  • 39 Answers
The installation is usually fairly simple. The hardest part is ensuring you ordered the correct parts for your specific computer/motherboard.
If you did when you open your computer you will see slots for your 1 GB DDR Ram (your existing memory will already be installed) and also some PCI/AGP slots for the ATI video card. These parts can ONLY go in the correct slots so unless your ordered the wrong stuff you should be able to figure it out.
Here is a diagram of a generic motherboard:
http://www.zoomcomputers.com.au/content/images/Motherboard1.jpg
For the DDR RAM you will need to remove your current memory in first. The new memory will go in the first slot on the left or top which is usually labeled Slot 0 or Slot 1 with the others being a higher number. You will want the new memory in the first available slot and any left over old memory you can either keep and place in the corresponding slots or just put aside. Most PCs will have anywhere from 2 to 4 slots for memory so feel free to fill them up. One note though: If your old memory is a lot slower than the new memory it may be best to just discard it. i.e. DDR 233 (old) vs DDR 400 (new). If you add those together the new memory will only operate at 233 speed. Usually it's not a huge deal and I almost always go for more memory and don't worry too much about the speed.
For the ATI video card, I will assume its an AGP or PCI-E card. There should be a slot in the card sections for it if you ordered the right one. If there is a card there already just remove it and line up the card and slots on the bottom just like you did the memory. It can ONLY go in one way so you can't really get it wrong w/o breaking it.
Posted on Jun 21, 2009
  • Gary Morrow Jun 21, 2009
    Did a little more research and you should be ok. Below is a link to a standard Motherboard for your Computer. If you look at it you'll notice the card and memory slots I was refering to and they will be similar (if not identical) to yours.
    The top left ones (white) are your PCI and PCI-E slots. The graphics card should go into the PCI-E slot.
    The bottom right (Green/Blue) ones are your Memory slots. You will probably have 512mb already installed. Just move it to the 2nd slot from the top and put your new 1GB stick into the top most slot. That should work fine.
    Once you boot your computer the memory will work automatically but the Video card will need to have drivers installed as well as your monitor cable (in the back of your computer) which is currently going into the onboard video controller moved to the new Video card.
    Inserting the cards should of course be done with the computers power OFF and the computer unplugged.
    http://www.skyline-eng.com/index.cfm?fus...
  • 2,404 Answers
Open up the side door before you do anything else. Look for a stick or RAM that looks like the one your going to be putting in. When you find the extra slot that the RAM is going in, your going to find two latches one on each side of the RAM slot. The memory itself is slotted meaning it can only go in one way. Put the memory in and line up the slot with the hold on the bottom of the RAM. It should snap into place and the latches will hold the memory into place.
As far as the video card is concerned, its going to go into a long white slot, it also can only go in one way, the metal part of the card will face the outside of the back of the computer and the card will snap into place. After you do this you might need to have to put a screw into the metal slot of the video card to keep it in place.
At this point you can hook up the monitor to the external video card and the thing you might have to do is install the drivers for the video card when you get into windows. It might not detect the video card properly which is why you might have to intstall the software for it.
Also do the memory first to make sure the computer sees it and boots up. If it does then turn the computer off and then do the video card. That way if there is a any problems it will be easy to figure out where the problem is right away.
  • Ben Wabnick
    Ben Wabnick Jun 21, 2009
    Go thru the steps i told you and tell me how things go.
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
    these are the specs you need!!
    Minimum System Requirements
    • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
    • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
    • Memory: 1.5GB, 16GB Free Hard Drive Space
    • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
    Recommended System Requirements
    • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
    • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
    • 18 GB Free Hard Drive Space
    • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
    Jun 15, 2010 | ATI RADEON 9550 Graphic Card
    I am trying to buy a video card for my D101GGC Motherboard. I know my motherboard has a PCI Express x16 1.0 slot so I will get a PCI Express video card. But can I get a PCI Express x16 2.0 card and will it...
    First, your RAM is already maxxed out and it is only DDR. See:
    http://www.crucial.com/store/listparts.aspx?model=D101GGC
    Secondly, PCI-E 2.0 is backward compatible with 1.0 slots.
    The RAM on the graphics card doesn't matter as long as the card is compatible. As far as how much...if you can afford 1GB, great!
    ATI or nVidia? That's personal preference. I have had both and was happy with both. Other manufacturers use ATI and nVidia chips and market them under their own name. Galaxy, XFX, EVGA, and others. Here are some mid-range boards from Tiger Direct:
    http://www.tigerdirect.com/applications/category/category_slc.asp?Lprice=100&Hprice=199.99&Nav=|c:3669|&Sort=0&Recs=10
    You don't say how fast your processor is. You may be better off going for a new board or computer.
    Hope this helps.
    Thanks for using Fixya.
    Dec 29, 2009 | Intel D101GGC Motherboard
    EA Sports Cricket 2007
    Well for a sport game the useual requierments our probably a : 1 GB ddr ram pentium 3 or amd 2000 + with a 256 mb card such *** nividia geforce 6800 or ATI RADEON Saphire x1650 pro for max gaming and speed.
    Jun 09, 2009 | ATI RADEON 7000 PCI Graphic Card
    Will a DDR Ram work with a DDR2 Video card?
    The on board memory on the graphics card being DDR2 will NOT affect the system memory being DDR.
    And the memory you want to add depends on the memory you have allready installed on your machine and what version of windows you are running.
    Please post back with more info on this.
    Dec 30, 2008 | Gateway 5200XL PC Desktop
    My hardware upgrade
    all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
    Mar 18, 2008 | Computers & Internet
    E-Machines T6528 PC Desktop Logo
    455 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
