Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE hdtv wont stay on - GE D52GW12 52" Rear Projection HDTV-Ready Television
My 2004 GE 52" hdtv
If you need a tube replacement, your best bet is to get a used one from ebay. You need to verify the numbers on the side of the tube. Note: this is a very hazardous part to be handling. If you do not have an electronics background I strongly suggest you not attempt to replace, then re-align the tv.
Mar 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Ge d52gw12 green power light flashes three times wont power on
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.Its listed under the RCA repair kits as RCA makes the GE models.
Feb 24, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Push power button lights and goes out three times then stays off Will come on after two or three cycles of button pushing
Replace the three Capacitors CP150, CP120 and CP114 very common problem for that model You can get that RCA repair kit from www.tvrepairworld.com RCA and GE are the same TV.
Sep 22, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
52 inch GE big screen projector
Your TV is a RCA even though it says GE its made by Thompson/ Deflection Board Call UED 1-800-648-6657
Dec 31, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a GE a735. It wont stay on
Go to the GE website, consult your manual if you still have it, go to RadioShack and see if they might have a replacement charging cord. Maybe at the GE website you can order the charging cord. Good luck.
Aug 04, 2009 | General Electric A735 Digital Camera
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
