Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
The plastic part that houses the impeller cracked on my flotec fp4012-001. Is there a replacement part?
  • 332 Answers
You would have to contact flotec----there should be a part for it,, depending on the age of it, they change the covers all the time to get people to have to replace the whole unit
Posted on Jun 21, 2009
How do I replace the impeller on a 4022-10 flotec?
separate motor from wet end usually reverse thread on impeller screw then impeller unscrews normally hold back of motor from turning
Jun 10, 2014 | Flotec Pool & Spa
I have 2 flotec cyclone pumps. Both need impellers. Where can I get them? I don't need a whole repair kit. Just the impellers.
I believe you can find it at this website.
http://www.pumpagents.com/JabscoPumps/Jabsco-Impeller-Guide.html
Good luck
RJ
Nov 10, 2011 | Flotec 1/2hp Cyclone Pump
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
I want to replace an impeller for a Little Giant submersible pump
This is a plastic impeller on a brass hub. If the impeller is loose it is probally cracked or overheated and melted, ether way you will have to break the impeller off of the hub then you will need to break hub loose from shaft. You can do this by putting pump in a vise and putting a pair of vice grips on hub and giveing them a sharp hit in a counter clockwise direction. you will need to replace the seal and impeller and should check to be sure than you can get these parts before you start.
Aug 24, 2009 | Little Giant Submersible Fountain Pump
Flotec pump takes long time to pressure up. Has worked fine for ~15 years + but noticed the last month or so it runs and runs even after water use is shut off. It's like it's half the pump it use to be. We...
This could be a problem it the pump caused by freezing, check your drain plugs first to see if their cracked or loosened. They will quite often be made if a softer nylon that will crack first and drain pump in the fation of many fail safes. A place to try on-line for parts that may help is "Optimus Home" But I would check the plugs first.
Jul 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Need to replace impeler on flotec pump
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try
PENTAIR WATER
STA-RITE INDUSTRIES
200 Tate Street
Union City, TN 36261-024
(800)-800-468-7867
(FAX)-800-390-53
Feb 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Finding Flotec impeller for a flotec pump modle FP4012
WW Graingers. Call them with model and serial #s. If you do not have an account with WW, These guys have what ever you need:
http://www.pumpagents.com/partpages/FlotecPumps/FP4012.html
Nov 20, 2008 | Flotec Corrosion Resistant Shallow Well...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
389 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
