Question about Magellan Roadmate 1200 Car GPS Receiver
Problem accessing screen options
The right side of the touchscreen does not work. i can click on the menu in the center and the zoom out on the left but can't get to page 2 or zoom in from the start map screen. have tried reset but no help.
thanks.
    President:
  • 1,111 Answers
You can try the reset but probably half the digitizer is bad
Posted on Jun 21, 2009
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Mar 27, 2015 | Apple iPhone 5c
Tip
Control Center Ubuntu
1) Gnome Control Center is the front end configuration applet
(capplets) which allows you to configure your GNOME desktop.
2) Appointed by the depth of the command interface, so that
it is not just easy to find in the Ubuntu-in.
3) Control Center will give you a merged
able to easily configure your Ubuntu
In a similar way as in Control Panel in Windows.
(1.A) The first way:
The upper panel
mouse pointer is positioned
Above System
Right click
the drop-down menu, left click on
Edit Menus
in a new window on the left side
left click on
System
the right side, check in Control Center
Close our window.
Then, left click on System and we got the opportunity to run the Control Center.
(1.B) The second way:
System> Preferences> Main Menu
Close our window.
(1.C) The third way:
Press the keyboard
Alt + F2
in a new window
type: alacarte
then left click
Run
Close our window.
(1.D) Now you have easy access to a control center in Ubuntu.
on Jan 13, 2010 | Computers & Internet
Touch screen doesn't work right
getting fixed by a dell support center will be the best option touch sensors are very dangerous to handle y outsiders
Apr 25, 2014 | Dell Inspiron One 2350 All In One 1080P...
Left side of touchscreen does not work as expected
You think it could be possible the beep will be heard where ever you touch the screen, because the sensor for that is different from the matrix that is scanning where you touch?
In my opinion, the touch screen is defect, and it takes a certified repair shop to solve the problem. Perhaps even the complete screen has to be replaced. before you agree with any repair, ask what it will cost and check what a new camera will cost.
Feb 20, 2014 | Sony Cameras
Split screen left side magnified right side regular how to quit?
Which version of OSX are you running?
Check in System Preferences under the Apple menu, then click on Accessibility and un-check the Zoom feature.
Also check Displays in System Preferences as well.
Oct 17, 2012 | Apple iMac Desktop
The fonts and items in Internet Explorer are about 100% larger than they should be. Can you advise as to how to return to default settings please.
In Internet Explorer 7-9:
  • You need to press the Alt key and choose View menu
  • Click on Zoom, click on 100%
Or:
  • Click on Page button
  • Choose Zoom, click on 100%
Jul 24, 2011 | Computers & Internet
How do you change fontz size on dell computer
  1. Change your screen resolution.
    • 1 Right click on the desktop and choose "Properties" (XP) or "Personalize" (Vista.).
    • 2 In XP click on the "Settings tab, and in Vista click on "Display Settings."
    • 3 Adjust the resolution slider to the right or left (right will set a higher resolution, left lower resolution) and then click "Apply." The screen will change to the new resolution.
    • 4 Click "Yes" to accept the changes.
    Alter the text size in the program you are running.
    • 1 Alter the text size in the program you are running. Many programs have their own font-size settings that can often be altered in a view, settings or options menu.
    • 2 Look for an option to change font size or zoom. Often you can click on a "View" menu and then click "Zoom."
    • 3 Zoom to the required size. (For many programs, you can hold down the "control" key and then use the mouse wheel to automatically zoom in and out.)
    Alter your computer's DPI scale setting in Vista.
    • 1 Right click your desktop.
    • 2 Select "Personalize" then "Adjust font size (DPI)," then "Custom DPI."
    • 3 Enter a number between 100% and 500% (higher numbers mean larger text).
    • 4 Click"OK."
    • 5 Click "Apply."
    • 6 Restart your computer.
    Alter your computer's DPI scale setting in XP.
    • 2 Select "Properties," "Settings," "Advanced."
    • 3 Click on the DPI setting you want to use in the drop-down list or select "Custom DPI Setting (other)" and enter your own number.
    • 4 Click "Apply" and restart your computer.
Jul 09, 2011 | Dell Inspiron 530s Desktop Computer
I have a samsung gt s5233 w edge and the touchscreen has failed. the left and right part of the screen is not functioning anymore. but when i press at the center, the right side of the screen activates....
check the conector of the touch, if the touchscreen connector is not connected properly just unconnect and connect properly ,if it does not work buy a touchscreen.
Mar 13, 2011 | Samsung Star GT-S5233 Cell Phone
My laptop screen is zoomed in which is making all my icons huge. It makes my Internet pages huge also. How can I zoom out so my screen is back to normal size?
use this if using windows vista/windows 7
Set the zoom level in Magnifier. This can display objects on the screen up to sixteen times larger than actual size. Follow these steps to choose the magnification level that you want.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Magnifier.
  2. In the Scale Factor list, select a level. The zoom level in the Magnifier window will change right away. Adjust the level until it's right for you.
use this if in windows xp
  • 1 Click the "Start" button in Windows.
  • 2 Select "Control Panel."
  • 3 Select "Appearance and Themes."
  • 4 Select "Change the Screen Resolution."
  • 5 Look at the left side of the "Display Properties" dialog window. About half way down the screen you will see a box labeled "Screen resolution." There is an adjustable slider in this box.
  • 6 Move the slider left or right, by holding down the left mouse button, and moving the mouse in the appropriate direction. Release the button when the slider is pointing to the resolution you desire.
  • 7 Click the "Apply" button at the bottom right of the window. The screen will go black for an instant, and then will switch to the new resoulution. You will also see a message pop up asking you to confirm the setting. If you are unsatisfied with the appearance, then click "no," and try another resolution. Otherwise, click "yes."
  • or try the accessibility mode
    1) press start goto control panel be sure use are in classic view
    2) select accessibilty options and select display tab and uncheck the enlarged icons option and apply and click on ok. this will reset all programs to a smaller view.
    ROB
    Nov 25, 2010 | Computers & Internet
    The screen 'moves' with the mouse... i move mouse left, the screen moves right etc
    1. Click on the Apple menu at the top, left corner of your screen.
    2. Click "System Preferences".
    3. Click "Universal Access".
    4. Turn Zoom off. The keyboard shortcut is Command-Option-8.
    Zoom is a nice feature if you want to see something close-up, but it's not nice if you can't figure out how to turn it off!
    Good luck! Please rate me if this solves your problem.
    Bot
    Jun 23, 2010 | Apple MacBook Mac Notebook
    Magellan Roadmate 1200 Car GPS Receiver Logo
    53 people viewed this question
    Top Magellan GPS Experts
    Marvin
    Marvin
    Will Halftowaite
    Are you a Magellan GPS Expert? Answer questions, earn points and help others
