Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Test kitchen aid dishwasher heating element - KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
larryyb
  • 291 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
  • 246 Answers
SOURCE: Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Posted on Feb 25, 2010
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Kitchen aid heating water
1) The heating elements +thermostat is the device for heating water. You must test this device in order to provide good clean dish. God bless you
May 08, 2012 | Frigidaire 24 in. FDB635RF Built-in...
Kitchen Aid Sculptura not pushing water up to dishes in order to clean.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Jan 04, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
My kitchen aid kudp02cr8s dishwasher doesn't seem to be getting water to the top rack and the glasses are not getting clean. How do you clean the filter?
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Nov 19, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a Kitchen aid tall tub dishwasher model #KUDCO3IVWH Yesterday the top rack didn't clean, today both racks stayed dirty - took apart the food chopper assemble and notice that there is water in the...
Check your heating element..
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2010 | Kenmore 16372 / 16374 / 16379 Built-in...
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Kitchen Aid Dishwasher not cleaning as good as when we first got machine. Have tried different detergents and rinsing more and even less dishes but that doesn't change the cleaning. It's still...
heatman101
sfnst4t134
Aug 30, 2009 | KitchenAid 24 in. KUDC25 Built-in...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
