Question about Philips SA5125/37 MP3 Player
Won't fully charge
I've tried a new usb cable and i've heard that the battery could be spent but how do you fix the battery problem. I can't find anywhere to open it to replace the battery and can't find anything in the users manual or on the philips web site that's of any help whatsoever. Is this something that has to be done by a service tech.
    Problem Solver:
  • 8 Answers
Yes. If it has valid warrenty you should use that.
Posted on Jun 21, 2009
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
I have Xperia X 10 mini from Sony Ericsson. I left it charging overnight as I do every night since I've got it. And today when I woke up, I took the phone and instead of it being fully charged and
Chances are your phone got too hot during the night and overcharged the Lithium Ion battery. If those batteries are exposed to too much heat then they won't have the battery life they used to have. You need to purchase a replacement battery or contact your wireless carrier to see about getting another one.
Jan 24, 2012 | Sony Ericsson XPERIA X10 Cell Phone
My kawasaki zx12 wont turn on.i've check the batery cables and ignitoin.it happened when i installed a new battery
A couple of things that may sound trivial or silly, but check and make sure your kill switch is in the start position.
Check your fuses to make sure they are all still good.
Make sure that when you turn the key you get a neutral light, if not select neutral and try to start it again.
Check you battery is fully charged, a battery that is below charge won't start a bike like it will start a car.
Did you disconnect any other wires if so reconnect them.
Do you have fuel in the tank?
Sep 18, 2011 | 2003 kawasaki ZX-12R
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera will not power up when opened.
Actually, it very well might be the battery. Batteries hold only so many re-charges before they become spent (shot, kaput). Try buying a new battery and see if this just doesn't fix your problem. My battery did same thing where it 'fully charged' and then as soon as I unplugged it, the cam had a nano of a second of operation before it seemingly went dead again. Needs a new battery.
May 27, 2009 | iSonic SNAPBOX DV566 Digital Camera
Sansa c150 will not turn on
IF it displays the logo, it seems to be a very common problem with this player.
I spent hours last night trying to solve this same issue.
Becuase the problem is SO common, and the information is so scattered, I decided to write up my discoveries on a wiki
Hope this helps!
Mar 26, 2009 | SanDisk Sansa c150 MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
Philips SA5125/37 MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
