Question about Pioneer HTD-510 System
Hooking up to digital cable box
How do i hook up my pioneer system to my digital cable box?
I have a philips tv. the tv has 3 ports each for av1, av2, monitor, and componet.
I just purchased a new Toshiba 40" 1080p LCD HDTV. I need to hook up to the TV. I read the instructions, but I'm not sure what goes where.
Posted on Jan 23, 2009
  • 59 Answers
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Posted on Nov 03, 2007
Connect mediacom cable to my apex...all the cables are hooked up correctly but it just says no signal.
What is the mediacom connected to? If the antenna connector, (usually screw-on type F) then set it to TV. Does Mediacom need to have a box between the cable and the TV? Sometimes cable systems do not use standard television signals, and a box is required to display on a TV.
If mediacom has a box, and cables are connected to (commonly red, white, and yellow) RCA connectors, then AV 1 or 2, depending on which connectors you plugged them into on the TV.
Oct 20, 2014 | Apex Digital Televison & Video
AV1 red, white and yellow cable ports not working. I use digital satellite service for my television through a box from my provider which only uses the AV1 port? I checked all the wires which were working...
Your post is a little confused (or I am!), why would a digital box only provide a low resolution output which is what the composite standard is - yellow video composite red/white=stereo audio.
You also say that you checked the wires, so you've seen the picture and heard the audio on AV2? So why not use AV2? There is no reason to use AV1 other than you may be using the other inputs for other equipment.
Check that the output from the cable box really is composite and not component, and if it really is composite check the AV colour system in the TV menu is set to Auto (or NTSC if you are in USA, PAL in Europe)
I think you (or I) may have misunderstood how to connect it, can you have a look at your cable box and see what the output sockets are labelled and report back/clarify also detail what your cable equipment is please?
May 17, 2014 | Panasonic Viera TX-32LX70 32 in. LCD TV
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
Mar 04, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
I hook everything up to the tv for the nintendo 64, but I still have no picture on the tv or audio. Help!
make sure your cords are in properly. You may have to get a new set of cords from ebay or your local electronics store. Also NOTE: Most TV's have AV1, AV2, Component, then Cable. AV1 and AV2 are both ports(usually on the sides and back), thatyou plug the audio and video into. Make sure both of these have no video or audio before you go out to purchase new cords.
Hope this helps!
Aug 09, 2010 | Nintendo 64 Console
How do i connect my Pioneer DV-250 to my Vizio 32 flat screen and Direct TV Black box???
hi there, is you tv black box hd? if this is hi-def you should have red/blue/green cable in/out to & from tv to box....dvd is out jacks to tv digital order to watch the dvd using remote tune to source tv/av1/av2/cable more
feel free to rate the help
Jul 10, 2010 | Pioneer DV-250
AV1 AV2 hook up
you should find them by seeing if you can find ports that are colored yellow, red and white
Apr 01, 2010 | LG 42LC2D 42 in. LCD HDTV
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
Jan 05, 2009 | Sanyo DS31590 31" TV
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
Pioneer HTD-510 System Logo
973 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
