Question about ViewSonic N1930W 19 in. LCD TV
ViewSonic channel autoscan not finding any channels
The CATV cable connects to the back of the N1930w. When I run the channel auto scan, no channels are found.
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
budmrtn
  • 11361 Answers
SOURCE: I cannot find hdtv channels on my viewsonic n1930w
Are you trying to get the HD signal from the roof antenna or from cable? when you set the tuner to scan for channels make sure it is set for 'CABLE' if you are on cable, or 'AIR' if using roof antenna.
Posted on Oct 31, 2009
SOURCE: Emerson LD195EMX - just bought from Walmart,
Hey, most stations are not broadcasting analog anymore. That is why you are only getting 10 channels.
Posted on Dec 08, 2009
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
Channel auto scan won't eork
channel autoscan doesn't work with some cable providers.....Are you connected to a cable like Time Warner, Charter, etc?? Who cares about autoscan anyway?
Jul 02, 2016 | Televison & Video
How do I run channel auto scan
Press MENU, use left/right buttons to get to input, then select AUTOSCAN using up/down keys and SELECT/ENTER button. This will take a while, 3-5 minutes. When it finishes, it will default to channel 2. At t.his point, push LIST button to see all stations it found.UP/DOWN buttons will let you select station of interest.
Dec 20, 2013 | ViewSonic N1630W 16 in. LCD TV
Viewsonic N1930w
Check its tuner. If tuner is faulty, this kind of fault can occur. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
May 10, 2013 | ViewSonic N1930W 19 in. LCD TV
Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
Jan 05, 2013 | Televison & Video
Have a curtis tv , trying to run autoscan, it runs, but it doesn't locate any channels. I have a comcast converter box also. Not sure why autoscan isn't working. Or do I have to set up my comcast...
For the auto scan to detect there must be channels present on the CABLE that is connected to the RF input- TUNER INPUT- of the TV.
So check with your cable operator for the channels and you can connect. however if you are using a digital box then the channels are memorised on the box as only the output of the box is connect to the video/audiop inputs of the TV. if so select line in/video 1/2.
Oct 18, 2011 | Curtis 326A LCD TVDVD Combo
HOW DO I AUTO SCAN CHANNELS ON VIEWSONIC VY2430
Do you mean the VT2430? Viewsonic doesn't list a VY2430.
For my Viewsonic TV, first make sure that your input is TV. (Press the Input button on the remote (upper left) or the TV (furthest right). Use the arrow keys or multiple presses of Input to change the current input.) Next press Menu. Use the up/down arrows to navigate to the TV menu (the icon looks like a TV). Press Enter. Set the type of incoming TV signal (Cable or Air or let the tv figure it out with Auto). Then go down to the line labeled AutoScan and press Enter. You may be prompted to begin the scan or to select the type of channels to scan. Press Enter again after making the selection.
Viewsonic has the manual for the VT2430 available on their site: http://www.viewsonic.com/products/vt2430.htm#tabbox_downloads . The direct link is http://www.viewsonic.com/assets/041/11502.pdf .
I hope this helps.
Sep 02, 2011 | ViewSonic NextVision HD12 HDTV DTV...
Auto scan doesn't find any channels
Make sure it is set to cable mode when searching and that the cable is secure in the back.
Mar 06, 2010 | Computers & Internet
I cannot find hdtv channels on my viewsonic n1930w hdtv monitor, but it does find them on my vizio 22'' hdtv monitor. Am I doing something wrong
Oct 31, 2009 | ViewSonic N1930W 19 in. LCD TV
Jun 22, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dont know how to get cable channels , i just get local channels.
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
ViewSonic N1930W 19 in. LCD TV Logo
824 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
