Question about GE 27998GE6 Cordless Phone
Plugged my cordless GE phone into phone jack "A"
64 year old female here. My room's phone jack has been labeled with the letter "A" taped to the wall right under the jack. Right next to the phone jack is where the cable TV cord comes out of the wall.
Does this have anything to do with why my cordless phone's charger keeps its little light blinking red: "Charging" or "in use" even when the phone is out of the cradle and even when it is fully charged, NOT in use and IN the cradle?
  • 1 more comment
  • nmdicke2 Jun 22, 2009
    yes dial tone...(but I guess I'd better stop asking for your help; I didn't know I had to pay for an answer. I apologize). also forgot the complete info: the wall plate is one plate- the cable TV comes out one hole and the taped on letters between the cable TV hold and the phone jack says "4 A" (maybe none of that matters- the plain old wired phone that I had plugged into that jack worked just fine. And my cordless GE phone words fine; I just wonder why the little red light on the charger cradle keeps blink, blink, blinking...the phone is fully charged and no one is talking on the extension phone, etc... If I will owe you money for yo ur time pleace cancel this request with my thanks for your time so far. nancy
  • nmdicke2 Jun 26, 2009
    thank you so much for easing my mind. you are a kind person to give away the knowledge you've gained. bless you and yours, nancy
  • Vitaly Kagan
    Vitaly Kagan May 11, 2010
    Does your phone get a dial tone?
    Champion:
  • 211 Answers
You dont owe me anything dear.
If your phone is working properly. Charging, incoming call and outbound are ok then you are safe.
Blinking light is called heart beat. It tells you that system is working. Let us know if you need something else
Have a great evening.
Vit
Posted on Jun 22, 2009
Internet connectivity problems HP pavilion a6230n desktop pc
1.Unplug all phone, fax and satellite TV cables from the wall phone jacks.
2.Plug the double DSL filter into the wall phone jack where the 2701HG-B will be located.
3.Plug the phone wire (for phone, fax, etc.) into the jack on the filter labeled "Phone."
4.Plug the gray phone cable into the other jack on the filter labeled "DSL."
5.Add the single DSL filters on all remaining phone jacks in the same manner, plugging the device phone cables into the filter. The single filters only have one jack.
Ethernet Connection
6.Plug the power adapter into the power port on the back of the 2710HG-B router and then plug the other end into a power outlet. This will cause the power light on the front of the router to turn green.
7.Plug the free end of the gray phone cable into the port on the back of the router labeled "Phone Line."
8.Plug one end of the yellow Ethernet cable into one of the four ports on the back of the router labeled "Ethernet."
9.Plug the other end of the Ethernet cable into your computer's Ethernet port. The Ethernet light on the router should now be green.
Wireless Connection
10.Plug the power adapter into the back of the 2701HG-B and the wall power outlet.
11.Plug the gray phone cable into the jack on the back of the router labeled "Phone Line."
12.Open the Network and Sharing Center on your computer by right-clicking the Internet connection icon in your taskbar.
13.Click "Set up a new connection or network" and follow the instructions provided by the wizard to set up the wireless connection on your computer.
14.Enter the SSID and WEP key when prompted. The SSID is "2WIRE" followed by the last three digits of the router's serial number, which is located on the bottom side of your 2701HG-B router. You will also be prompted to enter a WEP encryption key, also found on the bottom side of the router. The WEP key is the 10 digit number that appears in brackets under the first bar code.
Sep 12, 2012 | HP PAVILION A6230N DESKTOP PC
There is a buzzing sound on my end of the phone line, my computer is on DSL and sometimes it disconnects when the phone rings. I've checked the cords and the phone has a new battery.
You have interference due to the DSL overlapping your phone line its usually very common, make sure you have a DSL filter inline with your phone line , if not I would check out the RJ-45 jack in the wall, your phone jack and make sure that there isnt anything wrong with your Jack, you may have to call your phone company and have the phone tech's check out your wall Jack for any interference, they have special phone line meters to measure all this out.
Good luck,
Lex...
May 23, 2010 | Uniden Cordless Phone
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
We have a lot of static and loud buzzing on the phone
I had the same issue that started on some 3 year old 5.8 GHZ Uniden cordless phones. I moved it from room to room and same buzzing. I found a older Uniden set I had kept in a desk drawer. I swapped out the power transformer (power cord) and it is clear as a bell now.
Jun 15, 2009 | Uniden 5.8GHz Cordless Phone
Hit the deregistration button. phone will not work now.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
Jan 08, 2009 | GE 28111 Cordless Phone
Extream ststic
try a corded phone and unplug your cordless. see if that helps. If not go outside to your power meter and near it you should see a box labeled telephone. open it and you "should" see a spot to plug in a corded phone. you first have to unplug the little cord thats already in it then plug in you phone. If no static, then prob is in your house wiring or in a defective old jack or possibly another device plugged into your phone line (computer, answering machine, caller ID box, etc. ) .
If you do have static while outside & plugged into the "test jack" , then prob is in the phone companies regulated facilities and they will come out and fix no charge to you.
Jan 02, 2009 | Uniden Cordless Phone
GE Dect 6.0 digital cordless phone about 1 year- old how to set time
I have a GE 6.0 cordless & it did work great but, Now for what ever reason it crackels & the static is so bad i can not understand those who call me . I love this phone so please help me. ?
Mar 08, 2008 | Uniden Cordless Phone
Blown Resistor
because the phone will not work, first prove that it can. Try this: remove the battery and charge it. Read the voltage on the battery label. Read the voltage on the charger label. If the numbers match, then connect 2 wires to the battery from the charger (use tape) with positive terminals on one wire and negatives the other. after charge...about 2 hours, does the phone work?
Jun 07, 2007 | GE 27938 Cordless Phone
Ge cordless model 27831 issues
you have to place the handset 2 in on the main base by 'round 20 seconds so it will be registered by the system
Apr 28, 2007 | GE 27831GE2 Phone
GE 27998GE6 Cordless Phone Logo
340 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
