Question about Intel D945GNT Motherboard
Intel motherboard D945GNT - which is the most compatible ram
Which is the most compatible ram for the intel motherboard D945GNT. i.e 553 MHz/ 667 Mhz or 800 MHz ?
Thanks
Jayant
  • 2,229 Answers
According to Intel's site:
DDR2 667, DDR2 533, or DDR2 400 MHz SDRAM DIMMs
Posted on Jun 21, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Check you main board. if it requires a specified frequency, follow it. but usually it does not require, so the higher the frequency, the better. just make sure to put a same frequency if you plan to install more than one. (e.g. you can put 256 and 512 Mb with the same PC 2100mhz)
What type of RAM is compatible for my desktop pc for increasing speed ?
Your motherboard can support up to 8 Gb of ram, of type DDR2 667 MHz or 800 MHz. In practice 667 would do I believe as the performance difference is not great in practice. The board has 2 DIMM sockets for this.
It depends somewhat on your OS and what you want to do. I'd try 4 Gb first. Bear in mind that added ram doesn't actually speed the computer as such, only a faster CPU does that, but it will allow more windows to be kept open, and cut down on data swapping to virual memory on the hard drive.
Jun 05, 2016 | Intel Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
For Intel processor "Pentium 4
Dear abhay_patil
It should work but the 667 will throttle itself down to the 533 speed.
Its usually not a good idea to mix different speeds of ram together.
For a lot less headache its better to have same manufacture and speeds of ram together in the same system.
Hope it helps, if it did just give the thumbs up a click
Feb 10, 2011 | Computers & Internet
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Does intel desktop board d945gccr support DDR2 Ram 667 or 800 MHz
intel d945gccr supports ddr2 400 mhz & 533 mhz it maximum support ram is 2gb
Nov 22, 2009 | Intel D945GCCR Motherboard
Old computer ram upgrade without manual
564 mhz means it is a Pentium 3 or equivalent. This also means that the motherboard does not support DDR2 RAM which is exclusively for Socket 775 and Pentium 4 chipsets. Pentium 3 usually support SD-RAM, also but very rarely DDR1 RAM. Sorry but DDR2 will not work in your PC.
Mar 02, 2009 | Intel Motherboard
RAM Upgrade
let them install it for you. Go for DDR2 667. If it works, gret, if it doesn't scale down... But DDR2, and DDR 400 aren't nearly the same, they won't fit onto the same system, as their pin configs are different.
If the DDR2 doesn't fit, you'll have to go for the more expensive DDR 400.
Jan 05, 2009 | Intel Computers & Internet
Intel D945GNT Motherboard Logo
906 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
