JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
Problem for JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
Picture doubles and looks like 3d
By kingring42 on Jun 21, 2009
the pic looks like it is being squeezed from the top and bottom
Best Solution
posted on Jun 21, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Televisions & Videos  Expert
Rating: 93%, 574 votes
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Aug 25, 2009
Not Rated)
adrianbo
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
Screen looks 3-D ,Colors do not line up,screen is bowed or warped
Was this helpful?
Yes
No
Popular Solutions for JVC AV-56WP74 56 in. Rear
Questions and Unsolved Problems for JVC AV-56WP74 56 in. Rear
Do you recommend JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television?
Answer
Answer
i have a ge big screen model# 60gw947. while watching a show it made a large pop and then black... (More)
Answer
in color management, the red and green lights are flashing and the blue is not, what does this mean?
Answer
i was looking at tv and hit something on the remote amd the screen went blank now when i try to... (More)
Answer
jvc av-56wp74 56 in: my tv stopped working while i was watching it and starting making popping... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
