FixYa.com
Tags:
NEC ND-3550A-KIT DVD±RW Burner
DVD Drive Problem (by 3 users)
posted by jfernandez99 on Nov 03, 2007
Hello, i have a problem with my dvd drive and would appreciate some help. I have a NEC 3550A Burner and it won't read any disks. When I go into my properties from my computer, it says the drive is working properly. When I insert a disk into the drive, it tries to read it for a bit, then a pop up appears that tells me to insert a disk into the drive. I have tried multiple disks with different formats, but the outcome is all the same. Thanks for your help.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by macedonishe, posted on Mar 16, 2008
my nec nd-3550a can read cd but can't read dvd .pls help
Comment by SHAMP, posted on Dec 18, 2007
ITS NOT READING OR WRITETING NO DISC
Best Solution
posted on Nov 03, 2007
Helpful (85)
latinmcgyver
Rank:Wiz Wiz
Rating: 84%, 74 votes
one easy test to do is use a bootable cd and boot from cd instead of windows. if it boots its an issue in windows. if it don't boot its likely bad hardware.. i have exact same model drive for over a year
a good boot cd easy to get is a memory tester www.memtest.org the zip file has an iso i burn with imgburn.com tool
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 27, 2007
Not Rated (0)
trigger1937
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This has been a very common problem with the NEC 3550 drive. I've had the problem for over 6 months and basically had to stop using the drive in DVD mode. I've searched the web and no one had a "Solid" answer. The suspicision is that Windows or a virus updates a file in the registry and this somehow breaks the NEC DVD function plus a couple of other things. My system main disk got an error and would not boot Windows. A file in the Registry was destroyed and would lot even repair. I had to do a clean install of Windows plus all my software. Once this was done, all my original function of the NEC 3550a returned to top quality. I think I have proven this fixes the problem.
Can you Help with these CD and DVD Burners problems?
CD and DVD Burners
PUK code
my phone keeps asking me for a... Answer This...
CD and DVD Burners
audio cd branden
steeds insert a disc in ook al... Answer This...
CD and DVD Burners
JVC DR-MV7SU Timer...
I am trying to set up timer... Answer This...
stops burning at 99%
Hi, the problem I am having is... Answer This...
Only burns to 99%, this started...
Repair Service
Find CD and DVD Burner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
