Question about Maxtor DiamondMax 10 6V160E0 160 GB Hard Drive
Maxtor 160G hard drive - access denied
I recently had a Maxtor hard drive that would not boot(BSOD). The drive would just click but then bsod. I sent it to Seagate Recovery for an estimate for getting my data back. The price tag was too high($2500) so I declined and asked them to ship the hard drive back to me. I intalled a new WD hard drive and fresh copy of WinXP SP3. After booting the computer I connected the faulty hard drive and it was recongnized. Problem is when I try to access it I get the message(H:\ access denied), also when I look into the properties of this drive it shows(0 bytes available, 0 bytes used, and raw format. I need a solution to access this drive.
  • g_williams Jun 23, 2009
    I am going to try the freezing the drive, but I think that there might be another issue. I have full administrator rights but when I try to change anything about the drive I also get the error message that I don't have sufficient privilages to do so. Could the recovery company that I originally sent the drive to done something to prevent me from accessing it?
I have the exact same problem with my Maxtor 10 6B160P0 - though mine is in an external closure. One day it just stopped working. The drive is recognised, but I can not access it. I have been spinning about the net for a solution, and apparently this is a common problem with Maxtor 7200 ata-drives. It seems that the problem is caused by a corrupt firmware - which maxtor has installed on the inner rims of the drive. Apparently a firmware-update should mitigate the problem, and save your data - however, I have not come across instructions on how to perform the firmware update yet. If anyone knows this, please tell!
Posted on Feb 09, 2010
    Problem Solver:
  • 9 Answers
The drive is dead. Here is a solution that is not guaranteed to work but worth a try. Place the drive into a Ziploc bag and then place that into 2nd Ziploc bag, place into the freezer for 48 hours allowing the drive to get good and cold, once the drive is cold before removing from the freezer get computer ready to back up the files needed on the drive. I have had this work but only for about 30 minutes at a time max so plan on 15 - 20 as your target. Also keep in mind I have never had this work more than once so target critical files first. If this does work please rate.....
Posted on Jun 21, 2009
BSOD AFTER CLEAN INSTALL 2X
Since you are getting the same result from the same actions I would say that you should change the hard drive. It may be defective.
Mar 16, 2014 | Gateway NV79C48u Laptop
Sony Vaio PCV-Rs410, does not go past boot screen, and often goes into BSOD
Have you done any Hardware/Software Updates/Upgrades? Have you tried a System Restore/Recovery? Reseat the Memory mods, Graphic Card, etc. Try to boot to safe mode, Open msconfig, select Normal Startup, reboot. Let us know what the results are.
Jan 10, 2013 | Sony VAIO Digital Studio PCV-RS410 PC...
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
Windows Vista BSOD
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 20, 2010 | Microsoft Windows Vista Home Premium with...
Need to boot in restore mode. loaded a driver and its know going to the blue screen
Then press any key.
Then type "y"
Mar 13, 2010 | Computers & Internet
Blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
BSOD
This error means that the system is unable to access the boot device...for info on the causes and resolution of this error plz follow the following links
http://support.microsoft.com/kb/316401
http://support.microsoft.com/kb/324103
Jun 24, 2009 | Seagate Barracuda 7200.10 ST380815AS 80 GB...
Kernel stack inpage error
Hi Janhams,
Unfortunately the screen you are seeing has a name for it "the BSOD" or blue screen of death (click here for more info). by your description of the clicking sounds id say that it is an intermediate to serious hardware problem, but there are so many reasons for the BSOD that its hard to nail it down to just one.
That said the BSOD can happen because of conflicting software and/or hardware failures. Think back a bit and try to remember if you put any new software on the pc before this started happening. If you did, try uninstalling that software.
If the answer is no then:
If it were my PC as soon as i see the BSOD I would replace the RAM memory and wait to see if it happens again. You can find the RAM just inside the CPU its an easy job (couple of screws and your done) and i can walk you through it if you like.
If it did happen again I would reformat the hard drive and again wait to see if the BSOD shows its ugly head.
If you follow the two steps above and you still get the BSOD then you know that its a more serious hardware problem and needs some hands on maintenance by a professional.
If you choose to reformat and want to do it yourself please click on my profile and ask me How do i reformat.
Nov 12, 2008 | Computers & Internet
BSOD on XP64 fresh install
Here is an picture of the Blue screen I am getting
A larger version of the image can be seen here:
http://www.pjbproductions.com/bsod.jpg
it's a bit out of focus but should be ledgible. I don't think it's seeing it in the BIOS either. I will confirm tonight when I get home from work.
Apr 08, 2008 | ASUS P5LD2-VM Motherboard
Can't find the cause for clicking noise and BSOD
From what I've read, the "clicking" is a sign that the hard drive is about to fail. The cause is using two devices (hard drives, CD-ROM drives, etc.) with different read/write speeds on the same IDE cable. For instance, you MUST not have an ATA100, ATA66, or ATA33 hard drive or CD-ROM drive on the same IDE cable as a faster ATA133 hard drive. Hope this helps
Mar 16, 2006 | Maxtor MaXLine Plus II 250 GB Hard Drive
Open Questions:
How to Remove a Virus from Windows PC or Laptop - DataAlign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 17, 2018 | Toshiba Computers & Internet
See all Maxtor DiamondMax 10 6V160E0 160 GB Hard Drive Questions
Maxtor DiamondMax 10 6V160E0 160 GB Hard Drive Logo
335 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
