Question about Sharp LC-26D4U 26 in. LCD Television
LC-32D6U GETTING NO SOUND - Sharp LC-26D4U 26 in. LCD Television
    President:
  • 1,077 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (rubbing alcohol works quite well). Despite what the images say,
YOU MUST REMOVE ALL BLACK RESIDUE FROM BOARD. IT WILL NOT WORK IF ALL THE RESIDUE IS NOT REMOVED.
This kit is Sharp Part Number: PSPKIT663WJZZ and is available from Partstore.com for $19.95. http://www.partstore.com/Part/Sharp/Sharp/PSPKIT663WJZZ/New.aspx
It’s possible to get the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. http://www.partstore.com/PartSearch.aspx?PartNumber=PSPAZA663WJKZ&hiddenInputToUpdateATBuffer_CommonToolkitScripts=1&x=26&y=14
Posted on Jun 21, 2009
2 Suggested Answers
  • 18 Answers
SOURCE: NO SOUND from Sharp LC-32D6U
Unplug the video cable. Plug back in
If that doesnt help try a different set of cables.
GOOD LUCK,
CNBY
Posted on Jun 03, 2010
Good evening. When you connect the computer system unit to a television sharp lc-32a47e AQUOS not hear the sound. Explain why. Thank you
The reason that you may not be getting sound is the cable you are using to connect the computer system to the television. Without that specific information I must speculate that this is the case. The only cable that carries both video and sound is hdmi. If you are using an hdmi cable then you must go to your compute system's sound properties and designate hdmi as the choice. Even if you are using dvi to hdmi it will not carry sound. A VGA (an RGB) cable will not carry sound.
On this television in particular there is input #7, which has an input for the computer system and an audio jack so you would connect an audio cable between the computer system and the television. It does not appear that you have to designate input #7 for audio to the television when doing this. It appears that the sound will come through automatically.
Feb 08, 2011 | Sharp LC-32D6U 32 in. LCD Television
GOOD LUCK,
CNBY
Jun 03, 2010 | Sharp LC-32D6U 32 in. LCD Television
My sound card on my sharp aquos 37 is shot. can i
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
Aug 23, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquous LC-37hv4u has no sound. All my menu setup and option are still intact. Can this be hardware? If so, what can I do? Thank you
Aug 17, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
My sharp aquos 32" has no sound. it just stop working
Have you gone into the menu to see if the internal speakers were accidently shut off (most LCDs have this feature)Try plugging a speaker into the audio output to see if it is producing sound that way. If so you may have a bad speaker.
Aug 14, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp aquos lc-32DA5U
check the input
the reciever or dvd maybe its the faulty unit not the tv
Jun 20, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos 37" has picture but no sound ? unplugged and changed audio back to factory settings still no sound? is there a fuse some were for the sound card ?
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case for my LC-32D6U.
Jun 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp flat screen no sound after moving it from downstairs to up
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U. My understanding is that a surround sound system would bypass the problematic part of the sound board which is why yours worked in your basement.
Mar 09, 2009 | Sharp Aquos LC-PD50U 50 in. Plasma...
I have a Sharp LC 32D4U TV and the sound is not working.
Try unplugging the power for 2 minutes and then replug/ turn it back on. This resets the TV's motherboard.
Jan 12, 2009 | Sharp Aquos LC-32D40U Television
Sharp LC-26D4U 26 in. LCD Television Logo
1,268 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
