Question about One For All URC-9910 LCD Remote Control
What is the difference between a Digital receiver & analog signal
I have two Receivers and I cant tell the difference between them... The cables look the same and the installer did not label anything....
Can you please help.
    Problem Solver:
  • 5 Answers
Look underneath and they will have serial numbers,codes that identify make,model etc
Posted on Jun 22, 2009
Configuring a Sony STRDH510 - 3 HDMI & 1 composite input
Is the composite/analog signal going into the same input as one of the hdmi's? i.e. DVD,BD, etc.? If so, the receiver can only look at one of those signals at a time. To use two different signal types going into the same function, you will have to manually select where you want the receiver to look - either hdmi, analog, optical, etc. The receiver defaults to auto-selecting which signal to look at, and will always look for a hdmi signal if one is available.
Dec 26, 2012 | Sony STRDH510
Digital surround mode doesn't work,just analog dvd 6ch.input
Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sep 29, 2011 | Technics SA-DX850 Receiver
Trying to hook up my yamaha eq-70 to my new htr-5063
You don't. No tape loop or other place to insert it between the analog sources and the amps for the front channels.
http://www.retrevo.com/support/Yamaha-HTR-5063-Receivers-manual/id/23658bh532/t/2/
You'll notice on page 22 they don't show a return (playback path) from the 'audio recorder' or the VCR. That's a clue that there's no tape Rec/Playback loop, which is required for any external audio processor.
You can send analog audio out OR you can accept analog audio in, but you can't do both at the same time. Sorry.
Just the same, IF you had a Tape Loop or could break into a Pre-Out/Amp In slot...
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on most late-model Audio/Video Receivers (*) will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
* But not the HTR-5063.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up IF you had a Tape Loop:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Amp-, Rec-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Amp-, Play-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Jan 27, 2011 | Yamaha EQ-70 Home Equalizer
No, i was looking for free advice
Be advised that the engagement of any device in a Tape Monitor loop will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In jacks; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out jacks.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Mar 26, 2010 | JVC Audio Players & Recorders
Rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Feb 14, 2010 | Yamaha RX-V1900 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
Vsx-d810s anlogue to digital switching problem
The 7.1 input is for the discrete *analog* inputs, ie your dvd player has a built in decoder and has
eight analog outputs for the eight 810 inputs. Digital stopped at the dvd player.
Jul 13, 2008 | Pioneer VSX-D810S Receiver
Sherwood receiver - AV-audio not working while audio-only fxns are OK
Your friend was probably right, the receiver is telling you it is in digital mode. Try switching to analog input, make sure mute is off
Apr 27, 2008 | Audio Players & Recorders
No Digital Output
"Unlocked" only means that it isn't detecting a digital signal on the input. "Locked" conversely means that it has locked on to a digital signal. My Sony receiver behaves this way.
Dec 05, 2007 | Sony STR-DA5000ES Receiver
Zone 2 Problem
Yes and no. You can get some digital signals to go to zones 2 & 3 but only PCM ones, Analogue always goes. I have a Denon DVD player connected to my 4306 with a denonlink cable. I had to connect RCA Analogue cables to the DVD input to get the sound to come out on Zone 2.
May 02, 2007 | Denon AVR-4306 Receiver
One For All URC-9910 LCD Remote Control Logo
79 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
