Question about Refrigerators
Water dispensor on freezer door does not work
I have a Kenmore M/N:106.52559100 Side by Side refrigerator. The water dispensor on the door does not work when depressed. The ice maker works fine and the water filter is not clogged so I know I have water flow to the unit.
    Sergeant:
  • 212 Answers
Usually you could have a bad water valve. the dispenser side of the valvle could be froze up. if not then there is a small micro switch above the dispenser lever.
Posted on Jun 21, 2009
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore refrigerator 106.56166500 quit dispensing water. Icemaker works fine. I disconnected the water line at the bottom of the front door via the quick disconnect and I get water from the supply side...
The line inside the freezer door is frozen . Turn the temp in the freezer , to warmer for a few days , and it should thaw . A dispensor heater is available , pt # WR49X10173 . Instructions come with the part .
Nov 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
May 14, 2009 | GE GSS20IEP Side by Side Refrigerator
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispensor quit working
the water line that runs from the bottom of the freezer door up to the water dispenser is probably frozen. I have run across this problem several times. you can take the line out of the freezer door, thaw it out and re-insert it, but chances are it will happen again. usually when you have that issue, there is a problem with the insulation in the freezer door and you will need to have the whole freezer door replaced. Joe
Dec 03, 2008 | Whirlpool GS6SHEXNS Side by Side...
I have a Kenmore side by side refrigerator/freezer. I am getting really slow flow from water dispensor (outside freezer side door). It takes 20 seconds to fill up a glass of water.
check to see if your ice cubes are well formed or hollow / if hollow replace your filter 1st and if no good replace your water line / if cubes are large and well formed the replace your water valve to fix your water problem.
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Water Leak
do you have a water dispensor?? is there ice in the bottom of the freezer??
Oct 02, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
