Question about Boating
The orange/red light on the flasher doesn't work,
I have a 15 year old lowrance bluewater pro 1220 indash on my stratos, the orange light went out, the thing still spins, but you can't see anything. Where can I get one?
2 Suggested Answers
hydetech
  • 113 Answers
SOURCE: Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Posted on Aug 19, 2008
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
What would cause the turn signals to work sometimes and sometimes not ?
A bad flasher relay would do that. They are usually located on the fuse panel and plug into it.
Jun 27, 2014 | 1992 Ford Tempo
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
Good luck from Headsets Direct!
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
Replacing a pull switch on an Encon fan. 4 wires. Didn't label wires before I pulled them out. Number on old switch is 1282M and 17292101 with A B C D labels. Can you tell me which wires go where? ...
I have just figured out the wiring to my Encon 5TD42WHC ceiling fan. (This is not to say your fan won't be different.) You can't use just any switch; the switches vary in operation. See the images attached. Good luck, and be careful working with AC voltages.
Dec 23, 2010 | Encon Industries (78018) Ceiling Fan
Unit turns on by itself
I have two Lowrance X 125 that I don't get any Power to.
Feb 07, 2010 | Lowrance GlobalMap 3300C GPS Receiver
Our lowrance x135 just quite working Its less than two years old, where do we send it?
Here is a manual for it. http://www.lowrance.com/upload/Lowrance/Documents/Manuals/x136df_0151-171_112003.pdf ,
Take it to a major marine outlet, they generally have access to experts who fix this type of equipment
Feb 05, 2010 | Lowrance Boating
Battery flashes between orange and green
The rechargable batteries have life and will go bad like any other batery. The battery needs to be replaced. Some of the older units are discontinued so parts are no longer available. New nebulizers can be obtained for as cheap as $100.
Mar 31, 2009 | Invacare Supply Group Invacare Corp...
Aug 04, 2008 | Boating
TV REPAIR
John, bad news, short in picture tube, not cost effective to repair, even if it was the tube is no longer available for that age set, the bright side is it doesn`t owe you anything at 15-16 years old, too bad the "new tv`s" don`t last that long, hope this answers your question, BMW Rider
Dec 07, 2007 | Televison & Video
Boating Logo
161 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
