Hoover automatic 830 washing machine - leaking from under bowl
Water is dripping from under bowl of washing machine. Drips are coming off the first round housing as you look up from the drive shaft.
I had a Hoover 830, many years ago, it went for 15 yrs. solid. :)
Now I have a Fisher & Paykel IW 812 Intuative Washer
they are heaps nice too ... maybe time to get one of them?
maybe?
Posted on Jan 09, 2008
    Scholar:
  • 146 Answers
The water seal has been damaged. Will need to be replaced by a qualified technician.
Posted on Nov 03, 2007
My f&p mw511 washing machine is leaking water out of the blue nozzle inside the machine into the drum everything else is working fine please help I've tried pulling it apart still drips need help!
replace the water inlet solenoid unit as there is a hole in the diaphragm that is allowing tap water to pass through and into the bowl
simple solution is to turn the tap off at the wall after use until the faulty item is replaced
Feb 17, 2016 | Washing Machines
I get a small water leak almost just drips under
when its come from the front of the doors it is gasket prob or else its coming from the tub then oulet is not properly fixed ..
Jun 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
LG Top Loader washing machine leaking when not in use
Remove the top of the washing machine cover to access thehot and cold water solenoids. Disconnect power to the washer and wioe clean around the the manifold. See where leak is coming from . it could befrom the solenoid valves threads.
Nov 25, 2017 | LG WFT1071TP Top Load Washer
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water drips after the wash cycle is complete
Check and see if the leaking is coming from the pump. There could be a leak in the hose that comes off the pump or there could be a leak in your pump. If there is a crack or anything on the pump then just replace it and your problem will be fixed. It's an easy and cheap fix. The pump is located right at the front of the washer on the front of the motor. Just make sure you clamp off the hoses with hose clamps before taking the pump off or you will have water every where. I hope this helps you and if you have any other questions feel free to ask. Good luck.
Jan 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Leaking washing machine - hotpoint aquarius 1100 - wm63
water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
301 people viewed this question
Top Washing Machines Experts
